- Sep 16, 2018
Wah! This is Wifi? Almost near Gigabit liao.
No, these tests are wired, not wireless.
IMHO Fast.com is not very good and not easily compare with the reports in this forum.Oic. I see that you are using SpeedTest instead of "fast.com". Any particular reason for that?
Hi, I'm intending to use EA8100v1 (gonna flash to Openwrt) to replace my DIR-868L as main router for Starhub 1Gbps plan.
I will disable EA8100v1 Wifi and is there any setting to configure at WAN port or set it to DHCP for starhub to allocate an IP address for it?
Thank you
DHCP is default so there is really nothing to do in that aspect. Wifi is also by default disabled.
hi Xiaofan, thanks so it just plug and play?
You need to flash the OpenWRT firmware, which may or may not be smooth.
For my EA7500 v2, I need to flash twice, the first time it will fail.
But please read the OpenWRT documentation before proceeding. And you may want to watch some Youtube tutorial as well.
I am not an Openwrt expert myself, what I did is very simple as of now. You may want to check out the following thread for more advanced stuff.
Starting OpenWRT on GL.iNet Travel Router for New Users
FOREWORD: Even though COVID19 restriction has not loosen much since the pandemic hit us in 2020, and it is still tough to travel abroad for vacation or business in 2021. However for some of us, we might still go for local staycation in hotels or prepare our overseas trip for essential businesses...
forums.hardwarezone.com.sg
Has anyone try X-Wrt firmware for EA7500v2?
Not sure if it has English GUI.
https://x-wrt.com/
X-WRT ROM download
https://downloads.x-wrt.com/rom/
For coverage, you are able to tune the wireless channel and channel bandwidth.
So far I have to say my openwrt experiment is not that smooth. Guess I have to spend more time learning and trying. Basic operations are fine but not for slightly more advanced stuff.
I have all kinds of issues with OpenWRT 21.02 with EA7500 v2. I think it simply does not work. So I have to run the snapshot version but apparently that is not very good either as opkg packages are sometimes broken. IPv6, DNS over HTTP and Adblock are working so it kinds of serve the basic usages as of now. But I have not been able to get wireguard server working yet.
On the WRT1900AC side, I run the official 21.02 version. But I still have issues with broken packages. And I could not get Adblock to work and I have to use simple-adblock which does not have good reporting. SingTel 6rd IPv6 and DNS over HTTPs work fine. Again I could not get wireguard server to work yet.
I'm using Openwrt 21.02.0-rc3 for my EA8100.
have installed AdBlock and DNS-over-TLS (Stubby & DNSMasq) and working so far
Since 21.02.0 using DSA driver, hardware offloading is not working for my EA8100v1
Why not give the official 21.02 release a try?
By right, HW/SW offloading should work with the DSA driver for the EA8100 and EA7500 v2 , at least that is the case with my EA7500 v2, with latest snapshot (post 21.02 release).
HW/SW offloading seems to work fine for my WRT1900AC with the official 21.02 release version.
Did you check your wired Ethernet speed to see if it reaches 800Mbps+, if that is the case then HW offloading is working.
Kaicheng83, can advise what you did to flash to openwrt? I tried a couple of times flasing squashfs-factory.bin but kept rebooting back to stock firmware. Thanks!hi Xiaofan,
you are right as I have some issues flashing openwrt to EA8100 but still manage to flash it after some try.
everything work after configure it's IP address and DNS
Hi Huffie,Kaicheng83, can advise what you did to flash to openwrt? I tried a couple of times flasing squashfs-factory.bin but kept rebooting back to stock firmware. Thanks!
Hi Xiaofan, got time to upgrade my EA8100 to official 21.02 and enable hardware offloading in General Setting under firewall and manage to get the following result with wired connection:
https://ibb.co/jHdvQnW
Hi Kaicheng83,Hi Huffie,
Linksys router using some sort of partition A & B for firmware.
So first you will need to flash OEM firmware (https://www.linksys.com/gb/support-article?articleNum=226212) assuming its version 1.
After flashing of default firmware, you can try flashing squashfs-factory.bin (you may need to try for a few times)
I did not note down the sequence so it will be trial and errors
