PC Hang at startup. Please help
CatLuVer
It just means that the mobo battery is dead.
I found the seagate seatools inside when i load the pc wif the Hiren's Boot CD. Now scanning my hdd for bad sector.
Hopefully i can be able to repair it and can boot normally. Then i will backup all my files.
voiceoflove
i think cmos no battery..
try buy a new cmos battery
u don nid to boot up to backup hdd, just take the hdd plug it to another comp and copy all the files lor.
CatLuVer
CatLuVer
I have changed the motherboard battery and go bios enter date and time and saved changes. But it still hang.
Then i go bios n see the settings... to see if i can do something.
Then i see my hdd is set IDE - 'Enhanced'.
I changed to 'Compatible'.
Now the windows can start normally. Seriously i dunno wat it the logic or wat i did.
Only thing is tat now it takes longer than usual to startup and go into windows. Loading so slowly :s13:
Mever mind. I will backup all my files tomoro. Ard 2 months later i will build a new pc
bhtan83
how long have u been using that hdd? if its more than 3 yrs the performance will drop significantly (just to share from my experience). so its safer to back up everything in case it completely broke down.
CatLuVer
I have been using it for 4++ yrs.
Ya i will backup asap n going to get a new rig soon. Thks for all the help :):)
