PC Hang at startup. Please help
bhtan83
I stay near sls. I can go buy a new hdd & ssd + Win 7 OS like wat u suggested. Do u think my current rig can support tat? Or just buy a new hdd & Win 7 OS.?
Thks very much
ur rig's spec is on the right? if yes, ur mobo can support up to SATA 3Gb/s only, but dun worry u can still buy a SATA 6 Gb/s SSD and put it in w/o any problem. just that u dun get the full speed of 6Gb/s SSD nia. but still worth getting, u will still see a huge improvement over hdd.
if ur budget is tight get plextor M5S 128GB $139, otherwise i highly suggest samsung 840 120GB $169.
CatLuVer
+1
CPU/ Ram/ HDD issue will casue system hang even inside bios setting...
TS kindly check your ram and HDD first.
I can go bios settings n check, it nevr hang. Once i exit, it starts and hang while the windows logo is seen. Thks
poor_poor
Plextor MSP Pro more worth it compare to M5S. Some shop give discount.
The_Undead
if you have another pc or laptop to create a bootable cd or bootable usb thumbdrive which includes many tools and utilities, then you can make one to test your hdd first .
Hiren's BootCD, Ultimate Boot CD, etc !
CatLuVer
i not sure.. some shop happy happy give discount :)
i bought it at 145 :)
Thks alot guys.
I checked the pricelist
Plextor M5P: Ard $150++
HDD ~ 1TB: Ard $80++
Win 7 OS: $120 and below
SO total i need around $350 +/- a few dollars.
CatLuVer
Just try and download hiren boot cd and see whether you can repair the windows os first bah.
Your bios can detect the hdd, so its not considered fully dead yet.
Hi,
Now there's another prob. The screen shows up whenever i turn on the pc:
I go bios set up the clock, then start pc. The pc hangs at the windows logo. Then i turn off n turn on again, i see this msg. Does tis means my motherboard also going to spoil?? Thks
CatLuVer
I just downloaded the Hiren's bootble CD and burn the image to a blank cd. I will try in awhile
