PC Speaker recommendation
virtualape
i swear by this. im still using it. good midrange and tweeters with a pretty decent sub for boom boom boom
RockaRolla
In before topup abit :s13:
I recommend JBL 104, non-BT version is $179
Much better than those small teeny desktop speakers, and yet smaller size physically than the standard bookshelf speakers
ExTreMisTxxx
rooks small.... is it enough to amplify for gaming/movies?
Gixxerfied
Using 104 BT version now..Running wired to my rig..
Was looking at presonus 4.5 but decided to go jbl..
RockaRolla
Yes, of course dont expect big boomzzz, but definitely more than sufficient enough.
Most of those teeny speakers dont go down as low as the JBLs, and they require a subwoofer to even match the JBLs bass extension
Although make no mistake, the JBLs arent some bass monster either. Its more of quality than quantity
coyote
As per topic, any recommendations?
Not looking for high end ones..... just an average one with some bass for light gaming and youtube/movies
Budget: Less than $150
Thanks in advance :s12:
Logitech z623...
