PC Speaker recommendation
8-lane
yeap agree!
PC Speaker recommendation​
As per topic, any recommendations?
Not looking for high end ones..... just an average one with some bass for light gaming and youtube/movies
Budget: Less than $150
Thanks in advance :s12:
Wah TS is back haha... so wat were the speakers that u got in the end?
zzzzzzz
Received & set up my Edifier R1280dbs, indeed it's good value and wow-ed by it, better clarity than my Harman kardon onyx studio, similar bass, main boost now is stereo for better entertainment enjoyment.
Initially hooked up via monitor's 3.5mm and had average sound and disappointing bass, ain't sure why maybe due to sound from DP. After trying plug direct to CPU with same cable then the true capabilities shines.
Abit big though, have to adjust my monitor higher & placed vertically... may have to consider reposition again in future
Sent from Poco F3 using EDMWER app!
buyed from where how come so cheaps $80 only?
dbs is the updated BT5.0 speaker with additional optical connection rite? can connect to your mothreboard optical out if it comes with one, should sound better
or can always get a usb dac for it to improve the sound though maybe overkill for such speakers and may not even hear the difference between dac and motherboard line out
:frown:
zzzzzzz
Oh cool... I saw a few ppl on Carousell selling their used sets... was wondering whether I should get it..
buyed new during pc show discounts more worth it
used set duno how much abused and still selling exp and no warranty if sudden kaput
:frown:
zzzzzzz
I have 2 pairs of edifiers at home, 1 for the study room PC and 1 in living room for streaming spotify from the phone. good bang for the buck
also got 1 portable jbl for picnic and swimming pool, but seldom use
me buyed 3 pairs of edifiers
i wonder @kittyklysm buyed what speakers
:frown:
Devilsire
from lazada, local seller with 2 year warranty.
Yeah with 2 x RCA line in, optical, coaxial and BT.
was $96 during 12.12 and + cashback $11+ so $85.
Very satisfied with the sound and aplenty of connectivity, will recommend it
Dracky
My recommendation is to get a small Class T amplifier for less than $30 from Lazada or Taobao, and buy a pair of hi-fi bookshelf speakers from Carousell. You'd get the best sound for $150.
bakuten
i would go carousell hoot 2nd hand altec lansing atp3
mine used for more than 20years....still sound great....this shiat was designed to last 4eva
Jackrhino
This is because using the monitor will use the monitor digital to analog (DAC) which is even more cheapo than high end motherboard build in sound card
8-lane
:frown:
Nowadays the pc/it shows really cmi... much less retailers participating than pre-pandemic.. think better to buy new sets online...
Kiasuman
:frown:
Very very good speakers. But one big con is it "sleeps". It'll auto turn off and takes a few seconds to wake AFTER it detects sound. If you're playing something that is soft, it might not wake up.
It's really annoying.
But for the price and space it takes, hard to find anything that can beat it.
8-lane
Anybody tried these Audio-technica AT-SP95 desktop speakers before? Good anot?
BlackWing1977
I have the R1850DB.. bought from Fuwell.... actually wanted this model.. but cannot find in SLS back then.. all no stocks.. only left this R1850DB.. really no regrets.. sibei solid. I also connect to PC which I have the Creative ZxR installed inside.
