PC Speaker recommendation
mimimipo
Even $200 bookshelves are an upgrade from the z625 lol... So there are lots of options, just how much you want to spend and how much desk space you have.
Stock bookshelves will have quite a bit less bass than the z625, so if you need similar bass, you need a good pair of passive bookshelves with a good amount of EQ. (This trick does not work with most active speakers because the internal amp cuts the bass at around 50Hz so there is no way to boost it back)
I don't need similar bass as I realized I don't watch stuff that requires strong bass. So active speaker should be enough.
What is the model for the $200 speakers? Just wanted to know some recommendations for a different price ranges so I can try to go listen haha
hyperfuse
Money no issue then just buy Elac Debut Reference DBR62 ($750 now) and a China amp capable of at least clean 10-20W, add +10dB of bass EQ, and you won't even need a T5 or S351DB subwoofer.
See, money is an issue after all.
If you buy T5, there is definitely a big bass boost compared to just R1280DBs.
If you buy S351DB, you can also feel that bass boost.
If you compare T5 + R1280DBs and S351DB, the difference is more complicated. On initial listening, you can't really decide which is better, the weird treble of R1280DBs that is audible to veteran listeners isn't present on S351DB, but the bigger cabinet of R1280DBs results in its in-room response to be more similar to other bookshelves (i.e. more midrange bass). This can be either good or bad depending on how much boundary gain you have and how much you want, which is a personal preference. S351DB, or in my review S350DB needs EQ to sound like bigger speakers. Which leads to the most important point - Any sound dissatisfaction (apart from high subwoofer crossover) of S350DB/S351DB can be fixed easily via EQ. The problems of R1280DBs cannot. Even if R1280DBs may sound better at stock settings.
Well my question is for either getting a t5 to add on to the r1280dbs or get a s351db.
In that aspect, money is not an issue la haha.
As I mention, I only use speakers once awhile if my ears are getting hot from a headphones.
So no point I get a top of the line 1k plus speakers. Money is not an issue, but wanna spend responsibly also la haha since already have the r1280dbs
LiLAsN
I can tell with most certainty that the Elac Debut 2.0 and above such as the Elac Debut Reference series will give you audio clarity far surpassing the audio that you will hear of the same movie at the cinemas. Cinemas include the Dolby Atmos cinema, IMAX cinema and the worst of the bunch, the normal standard cinema.
Take it from me having watched the same few movies in those 3 theatres and then because of the Covid days, it was brought to home streaming almost immediately. Even with the streamed version using lossy Dolby Digital Plus (DD+) with Atmos, the clarity will be one that will make you rather wait for the home version than having to go to cinemas and hear their crappy audio and lacklustre visuals (since there's no HDR in the cinemas).
The reason for this clarity is simple. The Elac Debuts have a relatively flat frequency response. Meaning, it can produce all the sounds of the human hearing (without sub bass of course which is from 50Hz and down to 20Hz thus why you will need a subwoofer for most speakers) at relatively the same volume. Meaning, no details are lost because all of the sounds can be heard and non is too overpowering and blocking out the volume of the other frequency nor are some of the frequency volumes too low that it will sounds like it is missing or muffled as a result.
Because of this amazing frequency response, you will most definitely appreciate the audio quality increase vs that of the cinemas and will most definitely want to show it off to your friends and family when they come over.
Remember, we are talking about speakers that only cost a few hundred but yet gives you audio quality that punches above its weight for speakers that cost thousands of dollars. Take it from me, I also have the KEF R3s that costs $3000+ and they sound very similar (frequency-wise) as these 2 brand of speakers produce an amazingly flat frequency response (which was further enhanced by my AVR's Dirac Room Correction to help flatten any peaks and valleys in the frequency response and phase and time aligned to give a more cohesive sound and wider but coherent sound stage).
Upgrade slowly. There's no need to burn thousands of dollars and whatnot in one shot.
You can start with the Elac Debut 2.0 or Reference speakers and just reuse any existing speakers as your surrounds. Then, when you come to appreciate the sound of the Elac speakers and you want to get the full spectrum of sound, you can consider getting a subwoofer that can do around 140Hz down to around 20Hz or slightly lower. It is a huge upgrade. It gives a proper rumble and tactile feedback that you've been missing out without a dedicated sub bass producing subwoofer. Not unlike those cheap and fake subwoofers from Creative that can only go down to 30-40Hz. It will not be able to give you the proper subwoofer experience that you get at the cinema that can give you that chest pumping effect.
Most importantly, take your time. It is better to buy a proper speaker that gives you the best performance to price ratio and then slowly spend on the best subwoofer and so on than to immediately buy a cheap set of speakers and subwoofer that produce mediocre quality sound.
If anyone here is willing to take this advice, do provide your feedback on your experience here so that people will know that this is actually the best route to take and they'll truly get the best bang for the buck audio experience. Happy hunting! (for your speakers I mean)
PS. The Edifier T5 subwoofer can only produce down to midbass and slightly touching sub bass of 38Hz. Imagine wasting your money on a lousy subwoofer that can only produce sounds from 80Hz (crossover between your speaker and subwoofer) down to only 38Hz as opposed to 20Hz.
This is the definition of throwing your money away especially since the Edifier r1280dbs speaker can produce sounds down to almost 50Hz. So the T5 isn't doing much in this regards letalone doing a job of a subwoofer producing sub bass.
Refer to wwenze's review. The frequency response of the Edifier R1280DBS is horrendous. So many peaks and valleys that far surpasses the recommended +-3dB of tolerance. You will be completely missing the mids and it will be overpowered by the bass and the highs. And even then, you will again be missing a considerable chunk of the highs as well. I wouldn't even consider these speakers for anyone to look at because they'll be missing a lot of audio information from those very huge dips.
wwenze's review: https://forums.hardwarezone.com.sg/threads/edifier-r1280dbs-sub-out-t5-review.6503077/
hyperfuse
Icic...so if I buy the t5 to add on to my existing r1280dbs, it's a waste of money and won't hear the woofer? Better off remaining on the r1280dbs without subwoofer?
I mean thanks for all the charts and measurements. So what u are saying is, if I get a non audiophile person, such as maybe my wife, I let her hear the r1280dbs without the t5 and I add the t5. There wouldn't be much of a difference in the bass region? As I say, I saying in terms of a general laymen and not an audiophile who is concern with all these very detailed frequencies. Just want a enjoyable music experience. Not critical listening.
hyperfuse
U recommend which? The elac debut 5.2 or the 6.2?
RockaRolla
If you have space, i recommend the edifier r2000db, its around mid-200s
If no space, JBL 104 + dac
if your budget in 500+ onwards, then its studio monitors all the way. You do need to factor in a dac (get one with preamp for convenience sake to adjust volume on monitors, alot of good and cheap ones like ifi Uno, some Topping/Smsl, all these around low 100) since studio monitors are just active not AIO like edifiers/logitechs.
JBL 305p Mk2/Kali LP6-v2 are the classic choices in this range, JBL is really dynamic sounding yet still really neutral, so it wont kinda sound dull/dead even when watching dramas/movies, while the Kali is slightly warmer sounding for a more relaxing session. Some other options in this range includes Yamaha HS5, KRK RP5G4, Presonus E5XT, Mackie CR5-X.
This price range is the best sweet spot for price/performance ratio imo. It will outclass any of these edifiers/logitechs, yes even their more expensive models. And after this price range, diminishing returns will kick in super hard, you will be paying much more to get meaningful rounded improvements. E.g. from 500+ range, you probably need to go till Genelec 8030C (2k/pair) or Neumann KH120 (2.3k/pair)
If dont want studio monitors, and wanna stick with AIO, higher budget range(500-1k), you can look at Kanto/Audioengine/Klipsch. Then higher on from that (>1k), the KEF LSX/LS50 or JBL 4305p
Glad that you dont mind going down to listen, its the best way to judge the sound for yourself. GL!
this is very interesting.. so the most ideal way its just optical direct to speakers and let the DAC + DSP to do its magic
No point Analog out to speaker analog in since the ADC > DAC + DSP? I guess this part is edifer believes its DSP is more superior or to optimise the sound for the speakers from the input it receives?
Most of these coys tend to do DSP to smooth the frequency response, not just edifiers, its a cheap way to optimise the sound
And not say no point, think of analog in (RCA) as an extra input? Of course, if you can straight optical in, why not, but in some scenarios, you may need the analog.
For e.g, I have the r2000db as tv speakers for my parents. It doesnt have subwoofer connections, so if I were to buy a subwoofer for them, I can only connect to the analog input on the edifiers, in this order, tv->external dac->subwoofer->r2000db
The lower end models with sub out wont have this issue though
RockaRolla
Checking r1280db specs, it can go down to 55 (not sure -10 or +-3db). If its +-3 @ 55, then the T5 wont really add much, however if its -10 @ 55, then T5 will be more useful, as you get more extension till 40+ for r1280db.
But in terms of sound quality, it will probably be like those standard subwoofer you get from those logitech 2.1, alot of boom only. For general laymen's enjoyable music experience its probably fine, especially for the price they are at (like 170, can go lower during sale with vouchers i guess?)
But personally, I will say dont get it. Better to save the money and upgrade your r1280db next time
hyperfuse
Noted.
Which is a better upgrade path to go?
Elac debut? S351db?
It's just for pc usage, not to watch movies as the speakers are for my desktop when I wfh.
For movies, I using soundbar with my tv. It's a whathifi soundbar of the year in the year 2013 by Philips. Still haven't spoil on me so it's still enjoyable watching movies on my oled tv. Once it spoils, den I will have reason to go look for a speaker/soundbar setup for my tv which I am willing to spend about 2 to 3k for it.
For now just for casual pc usage, which u recommend to upgrade from r1280dbs?
RockaRolla
Noted.
Elac debut? S351db?
S351DB seems to be a 2.1 with the T5 sub. You may get slightly better bass extension (because of the sub) than the Debut but overall sound quality Debut will be better, but you gotta buy extra amp and dac if you dont have them already, since the speakers are passive, so you have to factor in the costs as well
You can look at my post #868, just few posts above, for some other active recommendations <1k
hyperfuse
S351DB seems to be a 2.1 with the T5 sub. You may get slightly better bass extension than the Debut but overall sound quality Debut will be better, but you gotta buy extra amp and dac if you dont have them already, since the speakers are passive
Icic..yea I don't have an dac or Amp at the moment. Basically just using a USB creative sb play soundcard that is working from 10 years or more ago haha..
So with what u are saying, getting a s351db is almost the same as getting a t5 woofer with my existing r1280dbs? So are the studio monitors better in the s351db as compared to the r1280dbs?
Somehow I didnt place emphasis on audio hardware in the audiophile grade standard. I only upgrade in terms of monitor, office chairs, headsets..things I use alot in a wfh environment. It's like if u ask a female, to them any earpiece that can playback their songs is enough, no need good ones haha.
I see reviews of people buying the t5 subwoofer in various online platforms be it in usa or sg, reddit or whatever online platform..also have good reviews. I guess sound is really subjective for the general masses.
It's like if u ask someone who works in the office to care about 60hz and 144hz monitors, they wouldn't bother. Can serve its function as a monitor can already. I guess audio is the same. The general masses will probably find the r1280dbs and a t5 sufficient for a enjoyable music experience and all these charts and frequencies won't matter at all. Only those who nitpick are in the audiophile scene will be critical of it. Same like an office chair. An ikea chair is comfortable and can be use for wfh and is enough, as compared to people who buys herman miller ergonomic chairs. The cost difference is actually not justifiable, mainly due to branding, research and warranty.
RockaRolla
S351DB is not studio monitors
They are just the usual satellite speakers with a sub
In terms of bass extension, yes S351DB or r1280db+T5, should be around the same. But in terms of overall sound quality, best to go shop audition
hyperfuse
Thanks for the response.
So if u are in my shoes, and probably only using this speakers for an hour out of a 8 hour work day, and having already the r1280dbs, it makes more sense to just get the t5 instead of buying the s351db ya?
I am not an audiophile in any form.
wwenze
Take note that bass extension and bass volume are separate things. You can have things with good bass extension but no bass volume (e.g. most good bookshelves) or you can have poor bass extension but lots of volume (e.g. cheap subwoofers)
And don't underestimate what 10Hz can do, 40Hz vs 50Hz is roughly 0.3 octaves. And of course at 30Hz vs 20Hz is 0.6 octaves. The number of octaves per 10Hz increases the lower the frequency.
To illustrate, from 50Hz to 40Hz you can hear roughly 2 notes more.
Is it something audible? Yes. Is it something you can live without? Maybe. Depends.
Also note that room EQ targets always aim for louder bass. And then there are people who simply prefer more bass. And there is a limit to front L/R speaker bass volume, especially without EQ.
RockaRolla
From a cost effectiveness point of view, then yes, getting the T5 is probably better. From endless passion lazada store, T5 is 149, S351db is 300. So you are saving $150.
But whether the speakers in S351DB is better than r1280db and worth paying the extra 150 more is subjective, thats why have to go shop test. Endless Passion have a physical store to audition, you can go try
wwenze
I said the R1280DBs is at an awkward price and performance point didn't I. ;)
It depends on what you're finding inadequate and want to upgrade.
And if price is no issue between $150 and $300, I will buy Elac Debut B5.2 for $299 (Or B6.2 for $399 if I need more oomph - Take note bigger speakers need more space)
And then for the amp get a AIYIMA A07 for $100
Then download equalizerAPO for free OS-wide EQ and boost the heck out of the bass and also fix the room EQ. And also reduce the treble as recommended by the ex-VP of Microsoft digital media division.
And you will already have a system that sounds better than what a lot of "audiophiles" listen to. And the difference between this and "audiophile cables" is that, you can actually hear it. A lot.
Then next is whether you want to save enough money and room space to get a 30Hz subwoofer or 20Hz subwoofer or not.
hyperfuse
Nv heard of that amp. Just checked it out. Reviews like not bad haha.. so is that a USB amp? How do I connect that to my pc on board?
The only lack I find for my existing r1280dbs is just the bass to be honest.
So if I just change from r1280dbs to the elac debut 5.2, it's a big upgrade in terms of tonality and treble? ( apart from no woofer)
hyperfuse
Firstly get rid of that USB creative sb play soundcard, is a horrible soundcard.
Any onboard sound card will trash it easily.
Put it very simple, let's don't dive into technical details else those who are not technical will be
even more confuse.
Want more bass get 2.1 speaker setup like Logitech Z407, Edifier s351db, Klipsch Promedia 2.1.
If want easy to setup and don't mind spending more money than go for Klipsch Promedia 2.1.
However for that speaker only Bugis Junction Challenger and Adelphi have stock.
Most places Challenger I don't think have stock for Klipsch Promedia 2.1 except the Logitech Z407.
Reason why I never mention Klipsch Promedia 2.1 is because is a old design and not easy to
use if you need Bluetooth function.
Compare with either Logitech Z407, Edifier s351db there's input selector so easy to toggle between sources.
Klipsch Promedia 2.1 good thing are it's mid and bass but it in my experience since I use to own it.
Klipsch Promedia 2.1 depends on the source/soundcard that is being driven by.
For desktop recommend use internal soundcard like this one:
https://sg.creative.com/p/sound-blaster/sound-blaster-z-se
Or if you are using higher end motherboards some boards does use ESS DAC.
Bookshelf speaker is for clarify and balanced audio but more suitable for music, mixing and production use
than gaming etc.
Edifier R1280DBs is a popular choice which I also owned before but for games 2.1 setup bass
will be more deeper than 2.0.
So depends on your preference if you want a fuss free setup I will vote to go for Logitech Z407
despite it is the least popular choice here.
Logitech Z407 cost around $150, don't need to tweak any setting just plug and play.
If your PC onboard sound is crap can use a USB cable for digital audio playback so it
will tap on the Logitech Z407 DAC.
Which is why I would recommend that especially the USB DAC function.
If I need more music power I have Pioneer Andrew Jones 5.1.2 ATMOS speaker setup which I use for my TV.
But of cuz home theater speaker will be way better than PC speaker so if I need more audio power.
I can either cast or stream contents/music from my PC onto my Pioneer AVR receiver.
For starters, should I get that aiyima a07 as recommended above and replace my that thrash sb play usb soundcard? Hahaha..
I have been using that for my r1280dbs hahaha
Klipsch promedia 2.1 is like so old school haha...I don't like how it looks. Prefer studio monitor looks like the edifier r1280dbs. The elac debut also look ok for me. I am an asesthetic person so that klipsch one really look like those old sch PC speakers which I can't do it haha...
hyperfuse
https://shp.ee/4nepdz8
Is this the same?
wwenze
The closest data for comparison I can find is this two. Not entirely identical speakers but close enough.
index.php
https://www.audiosciencereview.com/.../edifier-r1280t-powered-speaker-review.16112/
https://www.erinsaudiocorner.com/loudspeakers/elac_db52/
So bass volume down to around 70Hz is identical for both. Beyond which the R1280T just gives up while the B5.2 continues extending while rolling off gradually. With a +10dB bass boost you can get the B5.2 bass to work down to around 40+Hz. See how a low-cost subwoofer suddenly doesn't feel that necessary anymore?
There's a caveat - Applying bass boost reduces the maximum volume by the same amount. For example the B5.2 has -30dB distortion at 40Hz @ 86dB, and we take -30dB (or 0.1%) as the acceptable limit of distortion. So applying +10dB at 40Hz means the maximum volume you can send to the speaker is "76dB" since the bass will be working at "86dB".
R1280T's distortion? Around 5% at 70Hz @ 86dB. You're not going to boost anything out of that. Did I mention that this speaker is completely balanced in its design? By working at the absolute limits its price range allows.
Looks like it. This one doesn't have power adapter.
I should stress that if you're getting the Debut 5.2 you *must* have a way to apply EQ since it sounds problematic without. This often gets omitted from discussion since most good setups already has EQ and EqualizerAPO is free anyways, but I understand there are some situations where EQ isn't available. In which case it's back to visiting the shop. Or get the Debut 6.2, that one seems to work well right out of the box. 6-inch speakers can be hard to fit on an IKEA LINNMON.
Which reminded me, I haven't asked about how big is your table or listening distance. Because if you're using it in a living room for example, then go nuts with the size.
hyperfuse
index.php
No just on a study room area in glass partition room of a 5 room hdb living room.
Table is a 3 metre in length carpentry table. But width only about 55cm. It's for near field listening. Basically desktop usage. Not tv
So if I buy the elac debut 5.2...I must buy an amp such as the aiyima a07. So it's 299 + 100. And there's no subwoofer as well.
So will that differ alot in my listening experience as compared to my current r1280dbs without a sub too?
