POCO X3
prostcode
Anyone updated to latest firmware and found the phone a bit choppy at times? They said must do master reset.
Posted from PCWX using M2007J20CG
EveMuffins
Think i'm gonna disable all full screen mode. Screen is big enough for everything lol.
I already disabled for all apps..but it still auto full screen. :s13:
Settings -> Display -> Full Screen Mode -> Then turn off/turn on the individual apps accordingly right?
prostcode
:s13:
Full screen display need to use gestures to go back and go home page. Sometimes can be a bit unresponsive. Need to try a couple of times. So I have also went back to buttons due to this.
EveMuffins
I'll use the method mentioned earlier - swipe up for the 3 buttons to appear. Tried the gesture method but not used to it.
kottty
is setting-additional setting-full screen display
Sent from POCO X3 using GAGT
prostcode
After the update my battery is super good. After charging to 100%, I've been using the phone for the last 4 hours and battery only went down by 2%.
Posted from PCWX using Poco X3 NFC
ccloh
I find the battery drain fast.
i have this issue when i first got the set and mentioned in this thread too. it was like draining 1% per hour on standby mode. 100% charge at night before sleep and next day wake up battery level dropped to 88% even with battery saver mode on. however, after like 1 to 2 weeks doesn't have this issue. probably you need to full charge and discharge a few times to season the battery
ccloh
How to activate swipe up for 3 buttons to appear?
don't think there is a need to activate. have used so many android smartphone and everyone are able to do that and i don't remember i need to do some setting for it.
newcell
Ok, many thanks. Will monitor.
EveMuffins
The Note 9 thread say if use normal charger instead of the fast charging charger in the box, can prolong battery life. Is this true?
Fast charging generate more heat and the heat may degrade the battery. But phones now have better battery management control so battery life degradation is negligible to normal charging.
twosix
If the phone feels unusually hot while charging then stop the charging. If it feels normal then let it continue to fast charge.
