POCO X3
prostcode
Anyone using PCWX? I think the app doesn't support 120z refresh rate? Like not smooth
Posted from PCWX using Poco X3 NFC
human_shieldz
The Note 9 thread say if use normal charger instead of the fast charging charger in the box, can prolong battery life. Is this true?
I think we'll never get a real answer but i believe to a certain extent, it will keep your battery life over a longer time BUT battery will degrade as you charge anyway so i think companies have made it in such a way that the degradation won't be noticeable. So if you maybe keep your phone for 2-3 years, that's when you'll notice it but then again people using iPhone also complaining their battery life isn't that good after 2-3 years.
So now, are you willing to wait 5 hours to charge your battery and after 2 years, still notice your battery life isn't that good anymore, or takes 1-1.5hrs to charge and see the same result lol.
Deathzz
chin cai just wack/charge/stress it lah. why so stressed over a phone that cost cheap cheap le. unless you are buying iphone.. and want to use for the next 4 years or so lol
newcell
Today I use my x3 nfc till 1% and auto shut down. Charging was fast using its charger. Phone external temp at the case around 35°C. Seem like the battery improved. Doesn't drain fast like before.
EveMuffins
Fast charging generate more heat and the heat may degrade the battery. But phones now have better battery management control so battery life degradation is negligible to normal charging.
If the phone feels unusually hot while charging then stop the charging. If it feels normal then let it continue to fast charge.
Tks..coz my hp usually use for 3 yrs..think will just go ahead to use the provided charger. Don't wanna wait 5 hrs just to charge. Really enjoying the fast charging..<1hr finish charging..
human_shieldz
I think to maintain your battery to last as long as possible, don't "overcharge" it. Once hit 100%, remove it or maybe wait for a few minutes more than remove. Also, try not to let it use until dead.
EveMuffins
Ya..I always do that..once fully charged, faster unplug.
I checked my batt usage..from 100% to 53%..used 47% on gaming.
Active: 4h55m (every 1hr+ got let the hp rest)
Standby: 5h53m
Seems like batt life not bad.
prostcode
Quickly update to 12.0.3.
Battery life is amazing! From just now 98% after using for 3 hours after charging to full!
rathalos
I unplugged my phone that's charged to full on Sunday night.. haven't plugged it in to charge since then.. now I'm left with 42%..
Moderate use cos WFH.. but I did make like 1-2hours calls, etc..
ktyandkyc
wa serious this is unreal
Sent from Xiaomi M2007J20CG using GAGT
rathalos
Ya, serious.. I'm also like WTF.. this thing sips power when on standby.. like one whole night 6-7hr when I'm sleeping it sips 2% only..
ccloh
Anyone came across matt film screen protector?
use the one for 9S that's the one i'm using now. the camera hole also nicely fit. since the fingerprint sensor is not on the touch screen so matt SP won't cause much problem. matt SP is definitely more anti-fingerprint than tempered glass
marshy
You mean the Matt SP for Mi Note 9S is same dimension as to X3?
