POCO X3
jingle_babble
hi, anyone using this as a 5G phone? does it work on M1 network?
goggled and it seems to indicate this is 5G enabled... but wondering if they are compatible with the M1 network.
twosix
This is a 4G only phone. But if course can use on 5G network but at 4G speed only.
newcell
Doesn't matter. It works as is.
Outside data auto on, at home WiFi auto on.
What else can I ask. Haha same same.
twosix
it will become a problem when both are on at the same time pulling data from wifi and 4G. if u have enough 4G data, then no worries lah.
Nakedtoes
Wifi auto on.. The wifi scanning need to on...means phone will auto scan for wifi 24hrs..not good for battery life.
twosix
my wifi, data, BT and nfc are always on with all my phones. never felt they are draining the battery.
newcell
I also everything on lah.
Had to free myself from all this small small issues mah.
eip1234
nfc is just a technology. u need to ask whether google pay app will work. google pay should work if u can download and install the sg version.
Thanks for advice.
Any brother/sister here using "export version" of the phone? With bootloader locked and Without rooting, can you use GooglePay to pay for mrt or buses here? Thanks.
divineone
looks like the shopee poco x3 is bundled w the fan and backpack for 11.11
no idea about price change though
edit: will be 249/349 as mention on Facebook
divineone
can share link?
https://www.facebook.com/100328588290894/posts/187379829585769/
Not sure you can see it, but u can visit
https://www.facebook.com/Xiaomi-Online-Store-Global-Singapore-100328588290894/
the post is 1d old
