sellbuyboy
- Sep 3, 2007
Aiya. Missed the promo. Got any promo coming up?
Hmmm, did you try to reset your phone after update?
The problem resolve after factory reset. No more battery draining. Maybe some apps running behind because can feel the back of hp was quite warm.
Thank you.
. Wasted my timeAiya. Missed the promo. Got any promo coming up?
anyone facing earbuds issues? like the volume will be low and sound distortion...
When using with Bluetooth earbud? No issue with wired earpiece?anyone facing earbuds issues? like the volume will be low and sound distortion...
Sent from HUAWEI EVR-L29 using GAGT
i thought my earphone got problem
Bluetooth earbuds is it? Might be the Trace Together app causing the issues.
Could be your earbud volume is not sync with phone volume. When you increase volume via phone, earbud volume still remain low. Try to activate developer options and turn on absolute volume under Bluetooth settingsi only use an earbud never try 3.5 audio jack.
Not sure.. maybe earbub quality not that good or other Bluetooth signal interference.
Maybe try current earbud with other phone to see if it's really earbud problem firstwill order any earbuds to test.![]()
what about sound distortion? crowded places or shops it will keep distorted need to put near earbuds then no sound distortions
