POCO X3
kottty
If the person manage to guess the correct pin and do a factory reset, can I still locate my device using the Google/miui find me?
nope..Google find is base yr Google acc log in and MIUI find phone is base yr MIUI acc log in.
Sent from POCO X3 using GAGT
bbcccc
battery for the x3 is crazy good
tankie sia
Sent from Xiaomi M2007J20CG using GAGT
twosix
Not only the battery life, the phone is also pretty snappy to use. It's my main phone now although I bought it to be a spare phone.
mcferrari
I have problem with my bluetooth connecting with my Android car stereo, last time using Huawei Mate 20 I dont have problem. I assume that this is due to software MIUI. Another is the GRAB APP for Grabhitch I cant zoom the map to check the location pick and drop off of customer
mcferrari
Actually its a hit or miss, sometimes can connect right away and sometimes it takes time or didn't connect at all. Hopefully can be solved through future update.
pew
U all put your phone on the table screen up or screen down ar?
I put screen up with my previous phones...but this phone the camera bump quite big
Ye_Rongtian
Use a case... this case let yo put your phone face up on the table flat and without wobbling https://www.google.com/amp/s/shopee.sg/amp/Rugged-Armor-Case-For-Xiaomi-POCO-X3-NFC-X3-Xiaomi-POCO-X3NFC-Protection-Cover-i.285050255.4256537202
bbcccc
m using the ringke case
wun kana camera
tc4237
Screen up. The angle of it will already lift camera bump off the table.
human_shieldz
They finally delivered the phone after 6 months. The 120Hz screen is not really noticeable if you don't specifically go notice or compare it. The MIUI 12 seems fine out of the box but my 2 other Xiaomi phones, every updates bring about new issues lol. I just pray this one will be good.
twosix
I also can't really tell the difference with 120hz, but I still use it since it is a feature. Haha.
human_shieldz
I think you can only feel it all the time if you are using a flagship phone cos the speed + the 120Hz will complement each other.
I also realize if i set all the animations to 0.5x i can't appreciate the smoothness of the 120Hz, so now it's all back to 1.0x :p
Z_Dash
I noticed the latest update has major battery drain issues and boot loop (endless reboot) from reddit.
