POCO X3
Plastick
anyone on spigen rugged armor case? how is it?
edit: got it liao. been using spigen rugged armor for my past 3 phones, so far so good.
subisisniki
after updating to 12.0.8, the top screen for time, silent, wifi
etc icons get squeezed together for some reason
power on n off solves the prob temporarily but it will come back again
Sent from Xiaomi M2007J20CG using GAGT
Mine was intermittent wont be able to dee the icons. Now i restart (hold the off button). Seems oo. Will update again if proboem comes again
EveMuffins
I often get this kind of notifications though I did not download anything. Do u all get it as well?
ZhuTou!
FW?
Ur miui update setting is auto download first before install is it?
If its not fw, can use any file application like ES file explorer to look for the file and delete it
Sent from Redmi 10X Pro using GAGT
EveMuffins
FW?
File name looked like FW. But I'm already on 12.0.8.0 when I saw this notification. If it's FW, where do I go to search for the file? I can't find this file under Downloads folder.
Just checked settings and it is set to download automatically. I've turned it off. Will monitor..tks.
ZhuTou!
Try search for the file name using the app
Miui default have an app call file manager
If cannot find, can try using security app
It will scan for useless/big files asking if u wanna delete to free up space
EveMuffins
Tks for the tips.. have freed up space..:)
twosix
https://www.gizmochina.com/2021/03/09/376043-poco-x3-nfc-android-11-update/
An OTA(Over The Air) update with firmware version V12.0.6.0.RJGEUXM is rolling out to the users of the POCO X3 NFC. Here, the ‘EU’ in the firmware denotes that the update is currently live for the users of the European Economic Area (EEA).
Do note that, POCO X3 NFC also has other versions like Russia(RU), Indonesia(ID), Turkey(TR), Global(MI), however users in these regions will have to wait till Xiaomi expands the update to other regions. Speaking of which, the update weighs 2.5GB in size and brings the latest Android 11 update to the device.
If you recall, the POCO promised that it would keep updating the device for up to three years which means you are sure to get the next Android 12. As for another MIUI update, Xiaomi recently unveiled the MIUI 12.5 Globally.
It said that flagships like Xiaomi Mi 11 will get the update in the first wave of the rollout. And POCO X3 NFC, which is still on the MIUI 12 after the latest update, could get the intermediate MIUI 12.5 before the year ends.
Talking about the Android 11 rollout in the EU region, the update is still in the ‘Stable beta recovery’ stage meaning only a few users will get it now. After checking that it doesn’t have major bugs, Xiaomi will roll out the update to everyone in the coming days.
That said, this device, which is sold without NFC in countries like India(POCO X3), should also get the Android 11 update very soon.
Another link:
https://www.xda-developers.com/poco-x3-nfc-android-11-miui-12/
luei74
Anyone using Mi Move to transfer app data from other Mi phone to Poco X3? Is it good? I'm using 128 ROM is the process takes sometimes to complete?
tc4237
Anyone else encounter xiaomi apps cannot successfully install?
From the system app updater. Then everytime I keep getting prompt to install but install fail.
bbcccc
reboot yr phone
shd wrk
Sent from Sent from LG Wing using GAGT
simon_84
bought the blue one at 275 during lazada 3.3 sale period.
grey set is the cheapest at 269.
first impressions is that the camera notch and the thickness of the phone is way bigger than my oppo a9. :eek:
Z_Dash
Can i check what application you'll used to view photos on phone?
The xiaomi photos app somehow alot of my SDcard photos are not available.
The google photo not that user friendly.
Shutterbox
anyone tried G cam on this phone and outcome is better than x3 default cam?
