POCO X3
Lil_d3viLz
Is the ceramic mi 11 ultra coming in anytime soon? Considering that or new mi mix fold as present to my spouse.
sellun
Anyone using X3 NFC faces overnight standby battery drain issue? I always face battery draining from 7 to 10% everynight... How to i reduce? Daytime usage is great, only night time is disturbing to me. Always the android system uses the most battery.
ZhuTou!
Android system is FW issue, nothing much u can do, need to wait for update
Turn off those app with push notification that u seldom use like taobao, shopee etc
Auto sync app the lesser the better
Really depends on usage one
If u have lots of app with push notification, naturally ur battery will go down faster as the app keep connecting to network to check for msg/notification
simon_84
You can always set an auto off and on schedule to avoid the power drain issue.
Else the best way is to turn off notifications for apps that are seldom used.
Tbh, I never really understand why ppl don't switch off their phones at night.
Those on shift work or those in roles that are 24/7 is understandable due to their job nature.
twosix
feedback from other xiaomi threads show that if upgrade to miui 12.5, gestures from 3rd party launchers like nova will not work... sian... cos' i use nova and microsoft launcher.
wwh5210
Anyone has good TG screen protector to recommend? I am using Nillkin and it's quite bad.
yosemi
Anyone know in the APP page, the search bar is at the bottom. Is it possible to position to the top ?
phiber
the reason why it's at the bottom, it because your hand is at the bottom..
you don't need to reach on top to search.. i get their idea..
yuri2
got my x3 nfc today, the first thing i want to do is to insert the sim card.
damn, the manual don't tell you wtf it is.
good phone but the worst manual i ever seen.
i had to google and youtube to find where the bloody hole is to insert.
Z_Dash
I noticed my x3 nfc won't vibrate when set on silent mode.
Any means to have vibration with phone ring?
tc4237
Hole to insert sim card also need manual?
Need to tell u how to procreate anot?
