POCO X3
kazuki666
it is a partial release at the moment, if you don't update the moment you see it, it won't appear until the update is okay for full rollout.
Read HWZ Forum Rules on Poco X3 Pro
ah, thanks for explanation. Yes you are correct. I saw 12.5.7.0 while on data. Seeing its worth 600mb++ so i didnt update immediately. I thought I did click update when i got home with wifi. Now with your explanation, i understand it was apparently not updated... haha
Thanks :D
human_shieldz
Oh i'm blind, actually both my Poco X3 NFC and F2 Pro are on Enhanced. The word "Enhanced" is literally written there on the update page haha but its dark grey so i didn't see it.
carboy00
Thanks :D
Updated to 12.5.7 on my unit last night, I guess rollout has started?
kazuki666
I feel unless you need 5G in future, X3 NFC/Pro seems to have better specs compared to M4 Pro.
Poco X3 or M4 pro better? if M4 pro slightly more expensive.
Sent from Pocoyo Fan Club
As per above comment, same. But to clarify, you are comparing to X3 NFC or X3 Pro?
https://www.gsmarena.com/compare.php3?idPhone1=10802&idPhone2=11193&idPhone3=10415
I think the price of M4 Pro and X3 NFC is almost the same, specs plus minus should be M4 Pro better. But if you put in about $20 more for a X3 Pro, then its a different story already.
  • Gorilla Glass
  • Internal memory and UFS
  • better chipset and higher performance
The only advantage of M4 pro over X3 Pro should be its 5G network, which personally I feel won't be a gamechanger for another 1-2years.
If you can wait abit, X4 should be releasing in Q1 2022
https://www.gizchina.com/2021/12/10...-bag-eec-certification-q1-2022-launch-likely/
Techno Pride
I just updated to 12.5.4 today. Resisted the urge to purchase the Poco F3, since I've only had this X3 NFC for 9 months
hisugaya
Hi, those with Poco X3 NFC Global version, what is your full 12.5.4 update name? I missed updating my phone from 12.0.9, now I want to download the update from online.
EveMuffins
MIUI Global 12.5.4
Stable
12.5.4.0(RJGMIXM)
human_shieldz
Eh? Wouldn't the update status remain there? Mine has never disappeared. Next time just download and leave it there until you ready to update
kazuki666
On my X3 Pro, I realise when using the default camera app, I take pics and it will look off alignment. As in when I am taking pic, the object is in the centre, but the end result will be usually slightly to the side. Is it because of the qua-camera thus what I see in the centre may not be actually centre???
human_shieldz
Try gcam to see if it's like that. If so then maybe hardware fault.
Beepbeep8
Yes, I experienced that too when I used Whatapps to take pics. However its normal when I tried on normal camera and even gbwhatapps. Tried my wife's Redmi Note 10 Pro and my child Poco X3 GT, same thing happen. Guess its Miui bug on original Whatapps app.
human_shieldz
OK I tried default camera app and seems like no problem but on Whatsapp the screen looks closed up 1.5x or something, then after I take the photo, the photo turn out it's like 1.0 normal
