Yes, exactlyOK I tried default camera app and seems like no problem but on Whatsapp the screen looks closed up 1.5x or something, then after I take the photo, the photo turn out it's like 1.0 normal
On my X3 Pro, I realise when using the default camera app, I take pics and it will look off alignment. As in when I am taking pic, the object is in the centre, but the end result will be usually slightly to the side. Is it because of the qua-camera thus what I see in the centre may not be actually centre???
You guys are right. My fault, is the whatsapp cam, not default cam app. When using whatsapp cam, the pic I see and result will be different alignment. So I guess I arent alone. Should it be app or phone's setting?
Given how FB Inc sucks at fixing their Instagram problems, it's no wonder this is Whatsapp's issue. I've never noticed it cos I normally just take a photo with my camera and attached it to whatsappI tried Samsung Note 10, Oneplus, Oppo, all have similar issue
Can check other Xiaomi phones on MIUI 12.5 also... if they don't have the same problem then it is the phone... but it's quite unlikely... can't be a dead spot in the touch screen right? So likely a software bug?I am not sure if this is X3 or poco os issue. I remember I had similar issues on F1, then i thought maybe the phone is too old so it lags. Maybe only the F4 users can verify if they face the same issues? If they dont, then is phone and not os...
Seems to be MIUI issue, occurs with my Poco F2 Pro, X3 Pro and M3.I just found a super ridiculous bug though it's not consistent. Am using Poco X3 NFC.
When i pull down the control center and try to turn on BT, tapped so many times and it doesn't turn on, i have to go in to toggle it then pull down again i can turned it off instantly but then try to touch it to turn on again and it doesn't. Only after i toggle it 2nd time then it work.
Anyone has this issue? Not a big deal but it can be so annoying haha.
Better not be watching porn at max volumeOne problem i realise too, on my X3 Pro. My phone is connected to bluetooth earphone listening to music. and my phone is in mute mode. When I disconnect the earphone, sometimes it will unmute my phone also.
My Poco F2 Pro seems fine but mine is EU rom. So far it feels more stable than my X3 NFC and Redmi Note 9S but then again it's a powerful phone so some of the bugs could be non-issue.Seems to be MIUI issue, occurs with my Poco F2 Pro, X3 Pro and M3.
haha no lah. I have habit step out of house will mute phone. I frown whose phone will ring and beep loudly in public, so I make it a point i will mute my phone outside.Better not be watching porn at max volume![]()
Same. I hate those people that blast their phone even in quiet area. My father in hospital also listen to stuff loudly. Everytime he blast it, I'll move away to show its loud but he's like oblivious to ithaha no lah. I have habit step out of house will mute phone. I frown whose phone will ring and beep loudly in public, so I make it a point i will mute my phone outside.
So I wonder is this a bug... Weird one actually
I've had it for about a month nowX3 NFC 12.5.4.0 finally out again on OTA
Sorry to sidetrack. X3 Pro users, the latest is it 12.5.7.0 ???X3 NFC 12.5.4.0 finally out again on OTA
