POCO X3
1c3_5n0w
Damn ** sia..Ask me cancel.
this one really bs
Sent from Samsung SM-G975U1 using GAGT
justln
[Seller Basics] What happens when I accept the buyer’s cancellation request?
Shopee MY but the same rules should apply.
*Accepting buyer's cancellation request will not increase your Non Fulfillment Rate (NFR).
*You are not allowed to ask buyer to cancel the order. Any such violation will cause 2 penalty points imposed to your account.
Once you accepted the cancellation request, your decision is final and no further dispute can be raised by the buyer.
If you reject buyer's cancellation request and cannot process the order due to out of stock or etc, you will need to cancel the order yourself or it will be cancelled by Shopee automatically. *This will increase your Non Fulfillment Rate (NFR).
Should just message back, either you ship the phone a bit late nvm or I'll report Shopee about it and let the clock run out. NEVER cancel on your own.
Audiology93
Tried pasting my K30 tempered glass. Fit is just nice. The free back cover is high quality :eek:.
Sent from Samsung SM-N950F using GAGT
ahfish22
does anyone have the same issue:
theres no response when choosing 'SIM cards & mobile networks' in Settings.
and tapping it rapidly causes an error to pop up.
the only thing i did differently was disabled MIUI optimisations under developer mode to install microG + youtube vanced and re-enabled it after install.
might have messed up some permissions.
any idea how to fix it?
alvismah
WhatsApp data will move too? Saw one post mention data will not get transfer. Nv use before hence look for recommendation.
After using mi mover,please update if u got "third party app data" option to transfer Ur app data. cause mine don't have. I'm moving from Poco F1 to x3. Last time use mi mover for mi Max 2 to F1 able to transfer app data.
Shutterbox
does X3 have a flat or curve edge screen?
see some of those Tempered glass SC says 2.5D, will stick cover X3 screen nicely?
konoha
Alrite, I recieved ytd noon time, so at night dan i unboxed it.
So far so gd for me.. at 1st i tot the screen protector wasn't included then i realize they already paste on it! hahah coz i keep searching high and low in the box (how stupid of me).
Anyway i feel that the silicon casing is actually not bad wor, so for me i guess i will stick on the default screen protector and casing.
As for those who did not click on the free gift, yes u may PM the xiaomi seller, they really give the $79 voucher for you to purchase the shark cooler. coz i have redeem this voucher and check out. $0 cost and its on the way liao
Audiology93
Flat. I don't see any 2.5D curve on the edges. Yes those 2.5D glass should cover it nicely.
Sent from POCO X3 NFC using GAGT
ktyandkyc
The voucher can buy other stuff?
Sent from Xiaomi MI A3 using GAGT
