POCO X3
FloatingBarb
Very disappointing first experience buying from Shopee.
Payment and order placed on 11SEP, 8.20PM.
They only shipped out my parcel on 14SEP, 6.15PM.
So much for "shipping out within 24-48hours" huh? Now its stuck at "in transit from China" since 1PM yesterday.
If it makes you feel any better, I ordered 9/9 9pm and my order is in the same status as yours.
progene
Got mine, quite big the phone much bigger than my current Mi9T, play w 10min off and packed it back into the box
Hahahaha. So fast put back into box..
Sent from HUAWEI LIO-L29 using GAGT
progene
Think most of us.. the status is in transit from China.
Maybe they need to be quarantine for check...
ktyandkyc
Hope got custom rom, the interface I feel Abit laggier than mi a3, alot worse than custom rom PE
Sent from Xiaomi MI A3 using GAGT
Nuclear Boy
Halo Effect:
Isn't that just trapped air? Put a microfibre cloth on top, then use a plastic card or your thumb to push it out. If can't come out, then you have to lift it up again little bit then place it down and work the bubble out.
justln
Look at the sides, not the middle. You can't trap air at the edges. :s13:
Nuclear Boy
No matter how hard you push, the bubble just stays the same? I saw the same thing when I first applied on my RN9 Pro. Have to lift up and re-apply a few times then push hard more before I could drive out all the bubbles.
If you keep getting the same then it likely means your TGSP is somehow warped and uneven around the edges.
justln
I bought two pieces, I applied both, same issue, shiat quality. Probably too big dimensions wrong.
I applied a lot of SP myself and this is one of the lousiest quality I've seen yet.
Edit: This person also same as me. :s22:
n*****n
Variation: 2 PCS
Open frm box, item looks ok. But paste on then realised is defective item. The all sides/edges totally can’t stick on.
ab34fb3df834668f3d560bff274dd5e8
runningman.snsd
lol no 1 cares
Ultimo_Urien
Actually anyone compared the speed of the X3 vs the old poco F1?
Wonder how the new SD732 stack up agnst the older flagship SD.
KeYoKe
:s22:
n*****n
Variation: 2 PCS
Open frm box, item looks ok. But paste on then realised is defective item. The all sides/edges totally can*********t stick on.
If got loca glue, dap some on a card and go over the edges and cure with uv glue
EveMuffins
For those still in transit, don't worry leh. Me 9/9 9pm batch, in transit since 14/9 122pm.
