POCO X3
shortslippers
Mi Mover don't need to log in, just open the app on both of your phone and follow the instruction, it use your Wi-Fi network to do the transfer so it might take a while if you have a lot of data to transfer.
i found it. i mean like your apps that u have logged in no need to reenter all the stuff
Jurong640
How ur know your set is on this flight?
Based on my aggaration
somemore i see this flight HKG Cargo flying otw from HKG to SIN
whoooo
Got mine, quite big the phone much bigger than my current Mi9T, play w 10min off and packed it back into the box
ccloh
ahh.feel like a kuku.. manualling halfway...i read mi mover they map perfectly. dont even have to login the apps and set. true? shareme also?
for shareme not sure between 2 xiaomi phone how it works but i used shareme to transfer data from a non xiaomi phone to x3. it moves whatever you selected to a MIUI directory in the x3. so you have to manually go to the MIUI directory and copy or move them to the correct directory. example all the photo in Pictures directory will be copy to MIUI -> Pictures so you have to move that whole chunk to the root directory in the X3 after the transfer. for installed app though it moves all to the MIUI directory but they actually being installed in the X3 after the transfer as i could delete all those app in the MIUI directory and nothing happen
Apalis56
Very disappointing first experience buying from Shopee.
Payment and order placed on 11SEP, 8.20PM.
They only shipped out my parcel on 14SEP, 6.15PM.
So much for "shipping out within 24-48hours" huh? Now its stuck at "in transit from China" since 1PM yesterday.
shortslippers
It's now under the app named ShareMe. It comes with the phone
Open the app, then swipe up to see the other buttons, one of them is mii mover
mentioned by flame that mi mover ie embedded in shareme
shortslippers
the "stuck in transit" is around 3 days for everyone if u look at the logs posted
Hyperephania
You think xm cater a jet to transport your phone?
Sent from My Phone using GAGT
justln
That's normal? I dunno what's to be disappointed about, your delivery date is probably later than 25th Sept right?
If you get it later than that then KPKB ok, but now worry so much for what? :s13:
Sort of almost finish setup apps/accounts, cleared a lot of useless app, now left transfer photos and other crap files over + some home screen changes. Decided to use POCO launcher and other default apps see how. :s22:
