POCO X3
blade39
fully covered?
not really for curved only. it is common to have white edges. this is why they provide the glue. no harm using it...can use ipa to wipe off when u want to re-apply the sp.
Fully covered. The front camera hole also accurate.
I will try the glue then. Just the top, I worry. Worry drip into the earpiece holes.
After apply the glue, if want to remove the screen protector, is it very difficult?
Sent from Xiaomi Poco X3 using GAGT
wongminmin
ic..thanks! :D
no worries, just a little bit of glue...won't drip into...it will also dry very fast too....
nope....easy peel off.... just will leave some adhesives stain at the side...can be wiped off easily.
EveMuffins
My spare note 9 pro tempered glass SP can fit X3. But then I didn't apply as I think the SP edges might peel off when I take off or put on the xiaomi transparent case.
Wah..the xiaomi transparent case good quality one leh..
xenocide
the case is good but when u put in pants pocket, when u pull out, the pocket cloth also come out. quite "sticky"
wongminmin
look like the only way to check for warranty is via funan....:(
rathalos
Just got notification that mine is delivered! Gonna do the unboxing video tonight when I'm home..
1c3_5n0w
Hello everyone,
Some observations after using it for a few days:
- Case in box is pretty high quality
- Crazy vibrations on top half when playing videos, Note 10+ had this problem too
- Ghosting present, LCD low quality (GSMArena and 9to5Google had similar sentiments)
- Rear camera modules are great, front camera nothing special
- Haptics great for price range, major leap over Poco F1 and much better than the Note 9 I'm typing this on, but worse than Pixel 4As.
- Performance is great, I don't game and phone is able to last me a day and a half EASILY, with my normal non-quarantine use case, 2 days no doubt
- 240hz touch sampling very very very noticeable, my first experience was with the ROG Phone 2, but I feel Poco X3 is more responsive to my touch. MIUI optimisations????
- 120hz is ok I guess, but I adjusted very quickly back to my 60hz devices, missing nothing, I feel it's overhyped unless you game.
Sent from Samsung SM-N960U1 using GAGT
crunchyflakes
i cant seem to use the mi cloud home screen restore to when transferring from redmi note 8 to poco x3.. .anyone has any solution?
ktyandkyc
For me a huge step up over mi A3.. the display is awesome relatively .. same for sound quality..u guys can go do developer options set animation to 0.5x could be smoother.. for $300 honestly a steal
Sent from Xiaomi M2007J20CG using GAGT
justln
Possible to uninstall the default YouTube?
Or need to root?
I uninstalled using the Xiaomi fastboot tools, no need root. Chrome also no more cause I prefer Fitefox.
Nakedtoes
That one is oil not glue will seep easily into speaker and if sway into the screen.. Apply very small amount at a time. If u scare paste masking tape on ear piece.
