Pocophone F3
Hailgod
Together with the navigation gesture not working with third party launcher :s13:
found solution to the gesture thing.
  • Install Fluid NG
  • Choose the Launcher
  • Activate System Gestures ( they dont do anything)
  • IMPORTANT: activate Hide Fullscreen Navigation in the Same settings Page. Without that the Home Gestures are not working
Skyy
  • Install Fluid NG
Where is the Hide Fullscreen Navigation setting? It's in the Full Screen display mode page?
And the stupid FNG always gets itself disabled from the Accessibility page.. i've set it to Autostart, No Restrictions in the Battery Saver page, locked it in the Recents page.. but still after awhile it gets disabled from the Accessibility page
SuperDecker
Anyone using dark mode? Seems like it doesn't work well with some apps like dbs, taobao etc. It looks weird.
Skyy
bros using nova launcher prime, do you encounter double tap to screen lock will randomly not working due to accessibility and also cannot pull down notification shade?
Yes, just experienced it. same thing as FNG, the accessibility setting doesn't stick, don't know why.. need to yanjiu some more:cautious:
garychengjw
Hi to those whose GPay Transit issues were solved, apart from factory reset, any alternative method to get it working again? TIA!
try clear data for gpay and google service app. i did on my 4a 5G and works without factory reset. highly is translink issue and not our phone.
xKazeolus
i just started to experiment something maybe you can try too and share your results
1. Nova Prime also set autostart + no battery restriction
2. Nova Launcher under other permissions allow display pop-up windows while running in the background
after that do not touch anymore settings under both of them. just now i tried enabling and disabling full screen mode for nova launcher then the accessibility thing happen again. so far mine has been okay.
KeYoKe
battery drain didnt seem any better after debloat. - 10% overnight
Check the apps consuming the battery on that period ba since h have debloated
I do not have such issues at all
Without airplane mode with phone on cellular and wifi connected, overnight drain is about 3 percent for 7 to 8 hours
With airplane mode is about 1 percebt
Kindovic
anyone encounter issues where u cannot activate xiaomi's find my device?
something to do with SMS
