Pocophone X3 Pro
frizee
Lol, what does “Your parcel has been received by sorting center” mean”?
Any chance to receive by tomorrow? :)
lyk13
Anyone's F3 8/256 bought within first hour of release has shipped out?
freezerz
I have problem activitng my TPG SIM card on the phone.
Placed in both SIM 1 and SIM 2 slot, all cannot call out. Any advise?
KeYoKe
phone dialer dial in *#*#86583#*#*
there will be a message pop up saying VOLTE carrier check disabled, then reboot phone
i shared it earlier on but it seems like the migration of the hwz did not port the post over
for vowifi is *#*#869434#*#* but i have yet to try this before
freezerz
Thanks! It works now.
By disabling the check, do it means I'm calling with or without VOLTE?
KeYoKe
TPG calls can only work via VOLTE as they dont support 3g calling, hence in MRT tunnels or places where there is no 4G connection, calls cannot work
I believe VOLTE will work without disabling the check for the 3 big telcos Singtel, M1 and Starhub. but for MNVO like TPG etc, will need to disable the VOLTE check
By disabling the checks, you will see a HD icon at the mobile reception bar at your status bar, that means VOLTE is activated, hence you will be able to make call via TPG SIM, else you will need the TPG app to call
