Pocophone X3 Pro
Devilsire
Received my x3 pro. The phone, together with its casing is surprisingly thick sia given today's standard
And the rear cam design is protruding quite abit
KeYoKe
really thick.... but this camera looks like:
xenocide
Angtehkor
Just finish setting up my Poco X3 Pro. I have questions to ask you guys. If I use my Poco M3 cable and plug into my Poco X3 Pro 33 watt charger will it affect the charging speed or I have to use the cable that come with the 33 watt charger. Another question if I use the Poco X3 Pro 33 watt charger to charge my Poco M3 which only support 18 watt will I spoilt my Poco M3.
xenocide
u can use any cable.
u can use the charger
i using a 65W on my X3
KeYoKe
Why not use your poco x3 pro cable and charging brick? Then keep your M3 cable
m3 capped at 18w, means it will only draw 18w, and not the the full 33w which your charger and cable is capable of
