Pocophone X3 Pro
final1
Bought 1 unit of Poco F3 8GB/256GB black when it was up cuz it was 'cheap'.
But, not really sure what to do with it cuz i dont really need a new phone.
Anyway, the corners cut on this device are the camera, wireless charging and display resolution, in-screen fingerprint sensor. Overall, all pretty acceptable areas to cut to reach the price point.
I am not dinging the display, its already a good one for the price but i am used WQHD+.
KeYoKe
Tbh, i dont feel any difference between wqhd+ and fhd on my s21 ultra :s13:
since buy liao just play with it lor. Play finish sell it. Doubt will have huge losses for budget phones with good specs
LobsterX
this is the kind i don't like
the 4 air bags makes the case ugly
this case won't protect the camera.... will still hit the table when flat.
get a more rugged case.... Rzants / ringke ones can consider.
x3 and x3 pro cases are interchangable. no diff can be seen.
ahjunz
Your case si bei rugged.... i still prefer slimmer type :s13:
how i hope ringke or spigen come out with cases for them
Low possibility for the "bigger brands"
Nillkin has few cases and clear tpu for F2, but no clear tpu for F3
LobsterX
Thanks! It works now.
By disabling the check, do it means I'm calling with or without VOLTE?
basically is to disable the checking with telco if VoLTE can be provisioned to the phone.
some telcos purposely disable VoLTE on most phones they havent tested.... so by disabling the check, can force VoLTE on phone.
TPG is a 4G only telco. so calls will have to be made via VoLTE. on xiaomi phone using TPG line, we disable the VoLTE check to allow VoLTE to work on our phones....
Tested on my Redmi note 5 dual ai, mi 9t, mi 9t pro, poco x3, poco x3 pro, mi a1....
xenocide
can we have seperate threads for F3 and X3 Pro?
this is getting confusing
KeYoKe
Have u tested vowifi?
ceestudent
Small tips when you use TPU case, don't rub it with alcohol wipe. It will make scrub off the outer layer and end up your case become whitish very fast.
