Pocophone X3 Pro
wadsad
That's the same setting I did for my COD M, and, I realized if I enable 'Don't open notification shade', WA can be muted but unable to adjust brightness lol...
means must totally disable game turbo liao :s13:
frizee
But bro, apart from manually muting WA, if i disable game turbo, what is the setting if I wanna auto mute WA while having the option to adjust brightness?
wadsad
u try turn on DND? :s13: if i understand correctly, it should stop all notifications, but i nv put it into practice. :s13:
Hailgod
once upon a time, game booster had a auto dnd that actually worked. then xiaomi update it to game turbo and never fixed it
tszkitc
I got this phone on last Saturday. Everything is working fine just the battery drained a bit faster than I thought. I suspected the dual speaker consumes a lot of electricity.
Skyy
which phone are u comparing the battery life with?
Angtehkor
Watch video eat more battery
Diff model diff cpu also eat diff power
Cannot like that compare one la
This phone the endurance rating rated at gsmarena only 112 hours, so it will drain a bit faster but fast charging compensation it.
Angtehkor
well spoken by the master of battery! :s13:
battery master approve means good enough liao!
Now I really heck care about battery drain fast or slow, just use it heavily. And anyway it take less than 1 hour to charge the phone no need to wait until neck also long.
KeYoKe
power of fast charging... user usage pattern change accordingly. now no longer need charge phone overnight liao
