Pocophone X3 Pro
Angtehkor
power of fast charging... user usage pattern change accordingly. now no longer need charge phone overnight liao
Yup just wake up in the morning charge can Liao but must take note of the led light because this phone charge fast once the led light turn off have it immediately unplugged your phone to prevent overcharging. This Poco X3 Pro take 50 minutes plus to charge from 0-100% while the other phone I used it the past from 80-100% take 50 minutes plus to 70 minutes plus, that a huge difference.
twosix
phones nowadays will not overcharge. but to prolong battery life, charge it between 20% to 80% only, dun charge to 100% all the time.
tszkitc
I always leave my phone to charge overnight. Did not notice any different. It's difficult for us to monitor the phone during charging. My phone usually start to not holding charge on about 22th months. Time to change phone anyway......
Hailgod
I got this phone on last Saturday. Everything is working fine just the battery drained a bit faster than I thought. I suspected the dual speaker consumes a lot of electricity.
how fast is it draining? This guy did max volume max brightness youtube for 1 hour and it only dropped 8% (76-68).
without gaming, is it possible to kill the phone in a day?
badstudent
for those who cant find "turn on miui optimization", just go into developer options and tap on "reset to default values" several times.
xKazeolus
bros using adguard and bitwarden, any luck with them besides locking them in the background/recents...?
xKazeolus
u're saying these 2 apps keeps getting killed?
for me yes, haha. the accessibility option in MIUI isn't very friendly either thus autofill option wont always appear.
adguard will get killed whenever you clear recent apps, not to mention it will be killed silently when screen is off :ROFLMAO::ROFLMAO:
and to add on both are alr in autostart, removed from battery optimization/restrictions.
xKazeolus
I use blokada and locked it in background instead of running 2 apps
yea.. but some occurance when cleared recent apps, it will be cleared off. not always but it will happen. havent tried on miui 12 though but was hoping if theres some alternative besides locking it in.
xKazeolus
if anyone having issue with calendar/agenda widget not responding to tap, can go give permission to "display pop-up windows while running in the background". credits to xda :)
ZhuTou!
No need clear recent apps
6gb ram more than enough to handle
