Pocophone X3 Pro
EveMuffins
US eng for me
tks.. coz default was UK and I changed to US and was thinking if want to change back to UK.
btw if I want to change to UK English..I can do it at Settings -> Language. I don't have to do factory reset right?
SkyShroud
Ok. Thanks for the heads up.
LOL. Now googling how to go back to original rom from ArrowOS 11. Headache again.
Can I choose to use Miui then slowly debloat 1 by 1 based on my personal needs?
Double check: I just need to flash back to original latest xiaomi global fastboot rom V12.5.5.0.RJUMIXM then lock it using XiaomiMiFlash tool. Finally I debloat using this app on desktop. Then go to fastboot mode on phone and connect to PC. Right?
If you wan to reflash to stock rom, yes, you can check the guide
I never use the tool to debloat before, so I am unsure.
EveMuffins
out for delivery since today 1055am..think no chance of receiving today already..must wait till next Monday.
EveMuffins
this morning 7am+ I opened my door and I saw the shopee parcel. then I checked the delivery status..it was delivered at 1102pm yesterday :s14:
Lil_d3viLz
Welcome to the X3 Pro party. 4 family members under the same roof using X3 Pro too.
Guess now you are busy changing the settings and exploring the phone lol.
EveMuffins
ya..busy setting up the phones but luckily both sets delivered on different days so I can one day set up one phone..
btw I notice the games pre installed in both sets are different though both are x3 Pro and from Poco Global but 1 from Lazada, 1 from Shopee.
Lil_d3viLz
Can use the link I pasted here to remove alot of xiaomi and google bloatware. Then remove the games too.
Lil_d3viLz
https://github.com/Szaki/XiaomiADBFastbootToolsDownload the one above and put aside first.
https://download.oracle.com/java/17/latest/jdk-17_windows-x64_bin.exeThen download and install this one. This is JAVA, used to read and open the .JAR file above.
Connecting a device in ADB mode​
1. Enable developer options in Android.
  • MIUI: Go to Settings > About device and tap ‘MIUI version’ seven times to enable developer options.
2. Enable USB debugging in Android.
  • MIUI: Go to Settings > Additional settings > Developer options and enable USB debugging.
3. Connect your device to the computer. Launch the XiaomiADBFastbootTools.JAR.
The device is going to ask for authorisation, which you'll have to allow. Select File Transfer/Android Auto.
4. Wait for the application to detect your device. The device info should appear in the top left section. Bottom left should show "Device connected in ADB mode!"
Basically I uninstall all others until these are left.
Just tried Youtube Vanced. Works perfectly. No more annoying ads on Youtube.
