Pocophone X3 Pro
puteh83
You can try on laptop on google account under contacts. Once done, sync the contacts using hp. That's what I did after Whatapps Biz messed up all my contacts
I see...okok thanks...
but I think mine was messed up by sim card and google contacts...not very sure though... and same numbers have different color. not sure from which source🤣🤣
Read HWZ Forum Rules!
frozenoob
Anyone has this instagram issue where the ig story or reel briefly stops two seconds in? The entire video is smooth apart from that split second. It's quite obvious because you can anticipate the stutter.
Edit : issue went away on its own after a few days. Weird.
geekroute
just picked up the x3 pro today, 8gb ram version from shopee. any idea how long it takes to ship?
Beepbeep8
Hi, anyone used Poco X3 pro and paired it with Mi dashcam 1S via xiaomi home app? Tried with Redmi Note 10 Pro and Poco X3 GT, same thing can't download. Its seems like the latest Miui has bug that prevents the video from downloading.
luei74
Poco X3 GT 5G 8/128 (MTK chipset) having a flash sale at $329....like 30 mins only😠😠😠
SkyShroud
I see the Poco x3 GT flash sale price is $279. Good deal?
If you not gonna use custom rom, it is pretty good deal.
Poco X3 GT is basically equivalent to Redmi note 10 Pro 5g
GT is using mediatek CPU so not much custom rom support.
carboy00
Xiaomi POCO X4 Pro 5G: Specifications and hands-on photos leak of upcoming 108 MP, 120 Hz and Snapdragon 695-backed smartphone
Xiaomi is yet to announce the POCO X4 Pro 5G, but SmartDroid has already managed to get its hands on a unit. Not only has the website shown what the POCO X4 Pro 5G looks like, it has also listed the device's specifications, as has a recognised leaker.
logo_nbc_small_shaded_interior_white.svg
www.notebookcheck.net
Apparently there is a leak on the successor and the spec is really huge downgrade from this
Might be because the 5g component cost a lot.
Glad I got this phone while it was cheap.
really just a rebranded Redmi Note 11 Pro 5G. 🤪
Read HWZ Forum Rules! on Poco M3
Centronics
my phone isn't displaying the caller id information when there is a incoming call
uninstalled the phone app and rolled back to a previous version then the issue is rectified.
anyone also same problem?
I'mpossible
Hi all, keen to get poco x3 pro, just wanna check what is a good price for this phone? see on lazada got a seller selling at 328 but no review no past purchase, shopee like all no stock also.. any recommended shop/marketplace I can check out? Thanks~
SkyShroud
im not using miui, and no issue
i got it last year for around 260 iirc
now there should be limited stock and the spec is better than some newer budget phones so that price range is expected
