POSB Everyday Card
sglandscape
Last time can check, after they change to new layout cannot check already.
ApplePay can earn daily$ at Sheng Siong, they just credit the daily$ when the transaction posts; using the physical card will have the daily$ credited immediately.
Dont redeem at Sheng Siong, use it for CC bill offset instead if not the amount you redeemed will not earn 5% rebate.
Can't find the option to do cc bill offset in the new layout. Anyone has any luck?
Imhthc
There is a redeem rewards tab after cards but the app will ask u to launch PayLah! App to redeem. Think that’s the only way if u r using mobile app.
sglandscape
cards tab then Redeem Daily$ or Safra$?
Thanks, managed to do it via desktop browser, even desktop mode on the phone doesn't work. Cannot do via the app too. Paylah only allow offset against transaction, not against bill (which may affect the cash rebate given the the transaction).
Imhthc
Interesting. Since you u pointed this out, does that mean that the daily$ will be crawled back after you offset against transactions?
reddevil0728
Mmm not sure why you can’t be it’s working in mobile browser
ekardo
can I confirm that spending in Fairprice for this card only yield 0.3% even if $800 spending is met?
CrashWire
But these 2 cards need a min spend for the month in order to get the bonus cashback.
Same with Trust, 0.5% for non-members, 2.5% for members. Then a lot of useless spending hoops for extra Link Points.
At that point, UOB One's $500 or F&F's categories might look a lot better.
demoforce1
Wondering how many people are doing things for Trust, if not, will the PM just stupidly create a useless product?
