Post your rig!
Rubick
Intruder got DAC function. MK3B+ bo.
No brainer.
Also, u need more than $938 to get a can + desptop amp.
Period.
The intruder dac is 16/44.1 lol
Audio gd amp plus a akg q701 from amazon lol
Guan22
Complement! Like u looking for a complement for miracle wad lol. But most prob is intruder coz of local warranty
My complement is both portable.
Ur complement is 1 portable, 1 desktop.
Quite far fetched leh.
Rubick
If i were to find a headphone same sig as 8a, it would be lcd liao. That one burn bigger pocket lol. Think juz stick to intruder or mk3b+. Probably getting it when i back from bkk next wk
RazorLotus
i still dont get the idea of complement.
What does it mean if one iem complements another?
You wear both together will sound nicer?
I thought people just buy cause they like the sound sig. And they buy different sound sig for different songs or they just alot of money. Else buy 2 of the same sound sig, can just stick with 1 right???
Rubick
Complement means for diff sound sig lo. Like i got a bassy one i get a neutral one. Complement the bassy one when i wanna listen to more neutral stuff
Emospence
Compliment means, if an IEM sounds goot, the other IEM will tell it that it sound goot
Compliment
Guan22
There's no 1 IEM for all genres of music
Typically any IEM would perform better for specific genres
Hence, the idea of complement is to get IEMs of diff signatures so that more genres can be satisfied
Getting 2 IEMs of the same signature is a waste, ultimately they sound very similar
Noirkw
Amazing instrumental separation and bass. Since I listen mainly to post metal/rock, its a lot of guitar riffs, bass, cymbals and the occasional keyboard. the 400s takes in the genre very well. treble is a bit fatiguing and theres a bit of sibilance which is easily suppressed by a bit of EQ tweaking. it doesn't need a lot of power to drive although if fed well it delivers significant increase in sound stage "airiness" and depth, both bass and mids start to open up and becomes very forward. if you listen to rock, these are the headphones for you.
