[Printer] Laser Printer questions lip lai !!!
zijian20
Hi, looking for an office printer.
1. Mono or Colour
Mono. Laser or inkjet also can as long as printing cost is cheap and decent printing speed
2. Print, Print Scan Copy (3in1) or Print Scan Copy Fax (4in1)
3. Printing capacity per month
Heavy duty. Maybe 4k-5k
4. Budget
Depend on how reliable and cost of printing
5. Other extra requirement like wireless, iphone printing etc.
Wireless, wired, scan to network
Thank you.
Whizdom
1. Mono or Colour
Colour. inkjet
Print Scan Copy 3in1 . Fax don't need
Below 100 . Mostly for school revision notes .
4. Budget
$150 and below
Wireless a plus point but not compulsory
sgmichael
Hi,
To make sure that as you mention tray size can be adjust according $R but do printer have option to print $R ?
Thanks.
Hi,
Anyone can help clarify on above? (4R custom template)
If confirm then i may search at IT show for CM205fw.
Refer to post : #574 , #577
Thanks.
Gixxer1000
Photo paper (mate or glossy)
Not sure if you should be looking at laser printers as laser printer only have glossy papers and there is a border if you are printing photos.
If you dont mind, you can look at Fuji Xerox CM205fw as we have the best printout quality. Please note that though this machine have fax, you are paying not for the fax but more of the wireless function.
Support IOS/ Android mobile printing via Fuji Xerox App
How is the review for m205fw? Read about it like got paper jam issue
GameboyX
1. Mono or Colour
Colour. Don't like inkjet.
Print Scan Copy 3 in 1. Don't want fax.
Low. Below 100 per month.
4. Budget
Er.. value for money and cheap?
None. No need wireless.
tonerseller
1. Mono or Colour
4. Budget
FUji XErox CM205b.
Best print out quality and i saw the promo very very cheap now
ch33kster
Any reviews about epson L350? The ink tank system looks attractive. I am looking for 3-in-1, probably laserjet colour. Mainly used to print lecture notes.
Searchanddeal
L350 is a good printer if u do daily printing job. Print head support roughly 7 clogs and flushes. So if u dont print often not advisable. Ur lecture note printing I recommend u get a mono laser which is more cost effective.
Searchanddeal
1. Mono or Colour
4. Budget
Fuji xerox cm205b fits ur description and will be the best for value.
Eddied
1. Mono or Colour
Mono
Print
Low
4. Budget
Below $100
None
just need a basic printer, 2nd hand reliable?
thanks in advance :D
rAcEr
where to find cheapest fx printers after pc show? or should i just wait till the next it fair if not urgent?
chansl89
My P205B Fuji printer just spoiled .. Gave up in repairing it .. Any other recommendation for a toner ... Any budget toner printer beside P205B .. It is a disaster printer . Keep stucking and now it is dead .. dont event bother to bring it down to repair ..
Searchanddeal
Price is fixed across the market. Of course u can look for discounted printers in various shop etc challenger harvey norman.
