[Printer] Laser Printer questions lip lai !!!
yumakoc
Multi function brother laser printer recommendation?
Need scan, copy, fax, autofeed and compact design and good value. Color not necessary.
Bargainhunter56
If you are only looking at Brother models,
MFC-7470D @ ard $280 with no wireless
MFC-7860DW @ $348 with wireless
Both models are Print/scan/copy/fax with duplex printing capability
sky369sg
Hi, may I know Fuji Xerox DocuPrint CM305df 1 year warranty + 2 year warranty got cover
Drum ?
Thanks
tarui04
Hp and Samsung
What's good for print scan, networked colour printer? Home use
temptemp
your budget no more other brands options le. Just go for Fuji Xerox CM215fw
$499 + $80 ntuc vouchers
No duplex and smartphone printing only supports JPEG.
Toner
Black 2k pages $95
Cyan magenta yellow each 1.4k pages each $95 also
Warranty 2+2 years on-site
drum under warranty as well.
Best buy and editor choice from hardwarezone as well
Hi, if i have similar requirements but don't need color printing? b/w printing + color scanning. later going PC show to buy liao...
geckoSG
Need some clarification from fujixerox cm215fw users, there is no way for us to do network scan using a pc other than the docuworks 7.3 trial (which is NOT FREE). Cos I installed the full suite n found out that the software states in its Express Scan Manager tat scanning is via USB instead. Very ineffectively if so for a network printer.
N I do not want to do a 'scan to computer' using hardware button
geckoSG
This model currently on sale in IT show @ $499 w 80 ntuc vouchers. warranty is 2+2 years on-site. Good to hoot?
Also, how much is the toner for the model?
Oem is yuan100 ess shipping from taobao for an entire whole set
tangkw
Going down to PC show later, which Booth can I purchase the Fuji Xerox CM215fw at $489 + $80 voucher?
stevecsy
hi need help, looking at colour MFP, scan, copy, print & fax no duplex needed.
have zoom down to HP 276nw, Fuji CM215FW and Samsung 4195FW.
need to have scan to network (NAS/Google drive or dropbox). not sure which can do that.
need decent copy output too.
any1 have experience on any above to share?
Went down to show yesterday no more stock for Fuji.
TIA
geckoSG
FYI, Challenger pricing is same as the PC show for Fuji Xerox, no need to cheong all the way down and then OOS.
charcoal3256
Hi, looking for a new printer:
1. Mono
2. Print, Print Scan Copy (3in1)
3. About 10-50 pages a month
4. <200
5. wireless optional.
For print vs 3 in 1, what is the price difference for it?
And usually where should I purchase the printer fromto get a good deal?
Thanks in advance.
Bargainhunter56
Hp and Samsung
HP 177FW ?
SAMSUNG 3305W.
Samsung is cheaper but HP is wayyyyy better in terms of print quality compared to samsung. Almost comparable to fuji xerox models in that aspect :s13::s13::s13:
Bargainhunter56
TIA
Both fx and Hp models will be better than samsung 4195fw in terms of print quality. I know both models do scan to network, not sure if it fits ur exact requirement or not :(:(
Bargainhunter56
1. Mono
4. <200
Thanks in advance.
Brother 7060D (Print/Scan/Copy) $188
has duplex printing
Canon 3010 (Print/Scan/Copy)$169
is the smallest AIO
Fuji M215B (Print/Scan/Copy)$159
Cheapest to run and best print quality
All 3 above are without wireless :s12::s12::s12:
