[Printer] Laser Printer questions lip lai !!!
tonerseller
Thanks for your reply! I was wondering if the product is under EOL, how long more will the cartridges be produced before OOS :s11: Or the production continues?
Normally for original, they will manufacture for ard 5-7 years after EOL. Even now still can find toner for super old models.
Can buy compatible from me also I sure have it.:s12::s12:
eddytay
Printer Recommendation
Hi, I would like a printer recommendation.
1. Mono or Colour
Mono Laser
2. Print, Print Scan Copy (3in1) or Print Scan Copy Fax (4in1)
Print, scan & Copy
3. Printing capacity per month
Low
4. Budget
<$150
5. Other extra requirement like wireless, iphone printing etc.
Wireless
Thanks
Strykerpeli
Hi can help to compare? I looking for Mono Laser Printer, Wireless, Duplex and Can copy/scan.
I comparing Fuki Xerox DocuPrint M225 DW and Brother DCP -L2540 DW. How much the unit. Also very important how much is the toner and drums?
Thanks!
Strykerpeli
Hi also can get your contact? Interested if you carry the models i asked or the toner for future use. Thanks!
tonerseller
Thanks for the above. Further also can advise the price for the following:
1. Hp LaserJet M1522nf
Black cartridge
2. Fuji Xerox Cp205w
Black cartridge
Cyan cartridge
1. HP M1522nf
1 for $49
2 for $89
3 for $120
2. FX CP205w
1 pc (any color) $55
1 set (any 4 colors) $199
tonerseller
1. Mono or Colour
Mono Laser
Print, scan & Copy
Low
4. Budget
<$150
Wireless
Thanks
only Fuji Xerox M115w @ $149
tonerseller
Thanks!
My humble opinion: Fuji Xerox is better cuase I can give you 10 years warrnaty but as long as drum is not under warranty, the warranty never really cover much.
Drum is an important part of printer life.
M225dw $239
toner
standard yield $49 (1.2k page yield)
high yield $85 (2.6k page yield)
Drum under 3 years on-site warranty
DCP-L2540dw $218
toner
standard yield $54 (1.2k page yield)
high yield $95 (2.6k page yield)
drum $98 (12k page yield)
warranty 3 years on-site + 2 years limited carryin(parts only)
cracker
M225dw $239
toner
DCP-L2540dw $218
toner
Hi
What do you mean by your statement "Fuji Xerox is better cuase I can give you 10 years warrnaty but as long as drum is not under warranty, the warranty never really cover much. "
are u selling the printer too?
From the quotation that you had mentioned...
does it mean for Fuji Xerox, just need to get the toner replacement and the drum has a warranty period for 3 years ( What will be the replacement cost after 3 years?)
For Brothers, beside getting the toner, will need to get a drum replacement when 12k (1000 pages per mth) is printed which can quite awhile for those low volume user.
zippy79
1. Mono or Colour
Colour
Print, Scan & Copy
Low
4. Budget
$600 - $800?
Wireless & iPhone Printing
zippy79
I saw FX CM115W so much cheaper. Is there any same range as CM115W? Air Print, Wireless, Duplex and able to store paper. Look ugly then the HP one but seems value for money
winderen
Anyone know where to buy cheap canon toner?
do sim lim square sell? if yes, any shop to recommend?
tonerseller
Hi
Please do not misunderstand I do not sell printers at all. I menat to explain as a comparison with brother because brother printer warranty doesnt cover the drum and the drum is a key component of the engine. Thus, I quoted saying that vendors can give you 10 years warranty but as long as the warranty never covers the drum, it doesnt really cover much.
no idea but should be around $90-$100 for FX drum after warranty
Brother drum is $101. up price from $98
toner also up price from $92 to $95
As for the 12k drum replacement is subjective. I got customers a few months change drum cause spoilt. I got customers printer spoil drum still ok. Cant really give you a benchmark thus I will refrain from commenting.
tonerseller
1. Mono or Colour
Colour
Print, Scan & Copy
Low
4. Budget
$600 - $800?
have to take note Fuji Xerox CM115w dont have duplex printing
If you need duplex and airprint can go for
Brother MFC-9330cdw
cheaper than HP M277dw also
or Canon MF 8280cw
If dont need duplex printing but want sexy looks
Fuji Xerox CM225fw
some models I quoted you have fax but just ignore cause the prices worth more than the fax feature.
tonerseller
the lifespan of the rubber thing to catch paper is more important. :s13::s13:
paper rolller !! But now a days all vendors paper roll quite solid. Not much problem, except for samsung. But if compared to samsung older series their new series got improvement. Just need to catch up more with other brands.:s13:
