[Printer] Laser Printer questions lip lai !!!
MsiH97G43
can i check with you if you face the issue of the printer getting offline after awhile and restarting the printer do not get the printer online.
read some review on amazon stating this issue.
Elijahonli
erh i face this issue as well...
Called Xerox and they were awesome is solving that issue. All you had to do is to set the ip mode from auto to Static and solved
MsiH97G43
Thanks for the response. Glad this is a solvable issue.
Btw any comments on this printer? and also if you are able to advice the cartridge model for the 2540.
like2lurk
Hi bros, I'm a university student looking to get a printer at home so that I can print notes conveniently. These are my requirements.
1. Printing 80% mono, 20% colour
2. Print & Scan
3. Printing capacity per month = 100/mth
4. Budget = $300
5. Would be good if I can get wireless printing & auto duplex. Scan quality to be decent as well as I might be scanning photos or magazine cutouts.
Also, in this case would it be more recommended for me to get a mono printer and print my colour stuffs from printing shops?
Thanks!
Rgyl11
Current printer canon mp568 decided to b200 error me and I don't know how to fix it and ink cartridge error ...
Mostly mono, once in a while colour.
Print Scan Copy (3in1)
Printing capacity = No standard.. Once in a while when needed.
Budget preferably less than $200
Other extra requirement like wireless, scan to thumbdrive.. functions same as mp568 would be nice..
Please recommend something value for money can last for years best is cartridge easily and cheaply available
thanks!
rboyboy
Looking at Fuji P115W and P225 for printing school notes mainly but usage is low. Any reviews about them?
rainbow99
Dear all, am looking to buy a colour laser mfc for my boy. Am considering between fuji xerox CM305 df and brother MFC-9330CDW. My priority would be print quality, scan quality and stability (in terms of no paper jam). Doesn't have to print very fast and have many advanced features. Which would be better for my needs? Price wise, both seems quite close since promotions are still ongoing. Thanks for advice.
tonerseller
The price has rosed to $399/- I'm hoping to get it at around $250/- without rebate.. still watching the price..
You all talking about differnet model leh even thou printer image is similar
M225dw (3in1) $239
M225z (4in1) $309
M265z (4in1 full duplex) $399
:s13::s13:
tonerseller
2. Print & Scan
4. Budget = $300
Thanks!
No doubt the answer to your qn is yes get the mono printer will be fine. Color printer is not a important factor to your grades. With your requirement if you go for color laser it will be $600-$700 plus
For mono printer, I recommend you get Fuji Xerox M225dw $239 nia with wireless and duplex printing.
Print / copy / Scan function
tonerseller
Need duplex bo? If u need duplex just go for P225d. P115w is only when you dont need duplex and just need a very very simple printer
P225d drum under warranty
P115w drum not under warranty
tonerseller
thanks!
Suay sia you. Can do Xmas shopping for your inkjet printer. No inkjet can last you for years leh.
tonerseller
CM305df no qn ask. You haven see print sample right. You see MFC-9330 print sample you will straight faint
rboyboy
No dont need duplex. Where to find cheapest for P115?? :s11:
evildan
Hi guys,
I'm looking for:
1. Mono
2. Print only (Single function)
3. 100 pages/month (speed is not a factor)
4. As cheap as possible (<$100 if possible)
5. Wireless, auto-duplex, cheap replacement drums
Kind of shortlisted to Fuji Xerox P255dw and P265dw.
I am not sure why when i compare the specs, P255 seems better but older model?
Or any other recommendations?
AphoticFX
Hi guys, I'm looking for a cheap mono no-frills laser printer to print mainly my school notes. Recommendations are much welcome.
Are there laser printers out there with support of third party toners?
Thanks.
chong
I'm having a recurring issue with Fuji Xerox M205 f printer.
I'm a light user and after 3-6 months of use, every page will have somewhat faint horizontal lines. The lines cannot be gotten rid of no matter what I try.
The Fuji Xerox serviceman's solution has always been to swap to a new (same model) printer, and this has happened 2 times already. So this is my third set and it also developed the same fault after ~3 months. :mad:
I'm really appalled by the reliability of this printer. Anyone else seeing similar issues?
