Contact dlink hotline 65014200 tech support 24/7 to see if they provide assistance & firmware link.Bought this on 26/11/17 and have so much problem, can get refund?
you bought the adapter from a physical store? In that case just bring back to the shop say its not working and get a refund. Worst case they give you a replacement of the same adapter. If bought online just follow the returns procedureCalled yesterday and have a case number already.
The accent of the customer service officer (should be a Indian lady) very strong and find it very difficult to understand.
Saw a email this afternoon from their support and they claim that my computer has corrupted file instead of their product may have compatibility problem with Windows Home 10 (64 bit)
Pending their reply.
Agreed as it may be faulty device itself.you bought the adapter from a physical store? In that case just bring back to the shop say its not working and get a refund. Worst case they give you a replacement of the same adapter. If bought online just follow the returns procedure
Local shops will able to handle this 1 to 1 exchange.
Alternately go for a similar product as exchanged.
As i have no problem in model DWA 182 on Windows 7 64 bit.
This is USB 3 version.
As for your computer maybe run a OS system check, if you decide so.
https://support.challenger.sg/hc/en-us/articles/217007938-What-is-Challenger-s-Return-policy-Bought from Challanger but the receipt said good sold no refund.
As it can work but will cause blue screen or stop code, whether Challanger will entertain or not.
Yes, this is USB 3 type.
Yah Try on another machine if same problem might be the device is faulty out of the box.
This new driver from Realtek look suitable for this DWA 192. Till now no blue screen issue.
DWA 192 is AC1900 has far better spec than Edimax EW-7822UAC.what about the speed for 2.4G and 5G, acceptable? I own a Edimax EW-7822UAC, it is a AC1200 wireless adaptor, for 5G AC connection the speed approximately fluctuated at 220+/- Mbps, line of sight and 5metre away.
Exactly, that is why curious to know how good it performs.
From the system, it show the connection speed is 1.3 Gbps and it is quite stable. The distance between the router (living room) to this adapter (study room) is about 5 ~ 6M with short (900 width) rc wall/column blocking.
When closing the sliding glass door in between, speed drop slightly to 1.1 ~ 1.3 Gbps
Yes that is really fast, what about your speedtest? Edimax EW-7822UAC the connection is only at 867Mbps. Whereas the speedtest is only around 220Mbps
Did Singtel has speedtest based on Local Speedtest site.Downloaded speedtest apps from Store.
Download 61 and Upload 71.
My optic fibre broadband is 500M from Singtel.
When using my HP Samsung S7, i can get
Download 276 and Upload 249.
Why desktop connection is slower than handphone??
