Hello...
May I know for a Solafera - 0.73 E VVS2 price at $11k+ is it very ex???
guys, any suggestion for engraving on proposal ring? pls share...
have been looking around for a proposal ring, however i am stuck between buying from a private jeweller or from LeeHwa, Soo Kee, Larry, L&C.
I remember one of our friends gathering years back, one of my friend commented on the other friend's wife diamond ring praising that her ring looks big. But when he asked her whether is that a Destinee or Brilliant rose.. she said its a custom made from a private jeweller in Far East shopping mall. Then my other friend say, orh no brand one ah and then sudden there was a moment of silence and weird atmosphere follows.
Now i am in delimma whether i should get a 0.7+ct from private jeweler or only a 0.4+ct from Destinee/Brilliant Rose based on my budget of $4-5k, afraid my future wife will face above such situation in future if i go for the first option.
Got my ring photo!
Eventhough my diamond is not big but it look nice on it...
Hopefully my ring will look nicer under sun light... lol...
just few photo to share.
Actually is quite simple to choose...
if private jewelry can give a better diamond with lower price... why need to buy Destinee or Brilliant rose?
Those people that make comment like "no brand"... are those people that doesn't have knowledge in diamond...
branded jewelry shop not necessary has a better diamond than private jewelry shop. If you talking about 57 facets diamonds, it is a common diamond that can get in all jewelry stores... example, buying 1 carat 57 facets diamond at Lee Hwa cost you $15k, buy from private jewelry shop cost you $12k. Both are GIA certify diamond... why paying additional few thousand just for a brand name?
For me... i will want to pay to get the best diamond i can with my budget... i will not care about brand.
When you go oversea to US or Europe, will people know what is Destinee? What is Brilliant rose? Will they know who is Lee Hwa, who is SK?
People only will ask what is the 4C not the brand.
Hope what i think is correct. I am not expert, that is just my view.
Congrats!! Can see the shines in your diamond!
Btw, your ring looks similar to a solasfera ring video Jann Paul just posted on their Facebook.
wwwwwQ: Doubt u can get a 0.4-0.5carat for around 4-5k for the Destinee Royale or the Brilliant Rose. I recently asked a 0.5plus carat Brilliant Rose costing excess 8k.
Your budget definitely possible if you aim for a Solasfera.
Regards to your dilemma, I think its really impt to know what your paying for in order to appreciate what you have. Take a look at the comparison below:-
Normal Brilliant Round: 57 facets, hearts and arrows.
Brilliant Rose: 66 facets, no hearts and arrows (Also known as the Leo Diamond in the states)
Destinee Royale: 81 facets, 10 hearts and 10 arrows
Solasfera: 91 facets, 10 hearts and 10 arrows
Actually, its not how much facets u have on the diamond but the symmetry of the cutting which in this case with 91 facets, the Solasfera still has very minimal or none light leakages which makes it sparkles.
So I guess you just pay for the name only if you go branded.. not so much on the cut and quality. If "face" is an issue, definitely go branded.![]()
Did anyone customized this design here? I'm drooling over this.....
IMO, if you see this diamond ring on the street, there's no way I can tell the brand just by looking at it..
Depends on the design you want and if the online store has the design you want.. and whether you know her ring size or not... Resizing might be an extra cost again.
Emerald cut might be extra tricky to buy online as they have a wide range of length to width ratio... So some might look too long or too short... Need to consider the step cuts too.. Cos some is too thick, some is too thin... I considered getting an emerald cut before too![]()
