Proposal Ring - Part 2
Grizz.P
wahhhhh this octagon diamond is it improve version from angel diamond?
look like my angel diamond worrr~
this one nicer and more special shape than my angel diamond i bought years ago~
It's abit different. From the pics, the arrows are thinner and it's less squarish than the angel diamond. This one has 8 even edges whereas angel has more like cut corners. It's more towards a round rather than a square I reckon. Though I wonder how it will look like on a ring. I can't find any ring photos of it
Symbol
Saw the Octagon too~ Have to agree on the unique shape. Never seen that shape before. But I think my SO will like the Brellia more because it have a softer touch to it.
SeaKinT
You mean the scope images? Those are to check the performance (brilliance) of the diamond.
For certificate, stick to GIA or AGS. They are the better ones. Personally, I prefer AGS over GIA, but that's just my preference.
Most people will recommend you to go for a minimum 3 EXC (GIA) diamond.
Cut - Excellent
Polish - Excellent
Symmetry - Excellent
It's a good start.. but there is still much more to it. There are many 3 EXC out there that are still badly cut even though it shows "Excellent" on the cert. Don't just follow the 3 EXC blindly. To make sure you're getting a good 3 EXC, you can follow these steps.
1. Make sure the proportions are good.
How - Use the HCA tool
w w w .pricescope.com/tools/hca
Aim for a score between 0.4 - 1.5
2. Make sure it has good light performance
How - Use the Ideal and Aset scope to check. This is the colorful scope images you saw.
3. Make sure it has nice hearts and arrows
How - Use the hearts and arrows scope.
I went to a few shops and tried.. the hca score was around 3 on average.. some even 4+.. Hardly any even below 2... The lowest I saw was 1.7.. but the clarity out of range...
Some "branded" shops don't even let me see the cert. They say buy already then give me the cert.
I can't get pass the first step of low HCA score.. can skip this step?
straweffigy
How high you want the colour and clarity? I'd be more particular about the cut. It can make the diamond look bigger and "whiter". To me, clarity is the least important. I think 8k shld be able to get .8ct around there..
Not very sure about all these..
Maybe colour will be at least "E" and clarity VVS1/2? I don't know about "cut" for diamonds.
I can increase my budget a lil if there's a good reason to do so.. Otherwise, I'll work with 8k, inclusive of ring setting.
Draculav
Haha. That's the thing about the GIA triple excellent. It varies alot.
Correction to my previous post. It should be 1.4 or below (not 1.5).
Is the HCA tool essential? yes.
Is it 100% accurate? no.
It's a first tool to check if your diamond's proportions are good. If your diamond has a good proportion, it will have a low hca score, vice versa.
If your diamond has a high hca score, it already means that the proportions are bad, and it is most likely to have poor light performance and look bad under the scopes.
But that doesn't mean a diamond with a low HCA score is definitely good either.
A diamond has 57 facets and the HCA only checks 17 of them. So you will still need the other scopes to check the rest.
In other words, you shouldn't skip step 1 :s13:
hazel_ice
ya hor you are right~
think this week i go down see see...maybe i want get for ear studs :s13:
lcyMaGiX
I've been following this thread for a couple of weeks. Definitely learnt alot from bros here :D Now its my turn:
Got this humble 0.54 G VS1 diamond for $4k exclude settings
Any feedback is greatly appreciated :)
(Can help me post the images? :o )
i.imgur dot com /5ak06UX.jpg
i.imgur dot com /Fw2jk2e.jpg
i.imgur dot com /2LjMEsk.jpg
i.imgur dot com /zyjMOrG.jpg
ZippyRa
hi i am sourcing for my proposal ring too, i have a budget of around 3++k diamond + setting. is this budget abit too low for JP?! hoping to be able to get a .5carat ring. high chances is getting a super ideal cut because "round" diamond is preferred.
What are the price different between super ideal and brellia?! if opt for brellia if with the right setting is it possible that my diamond will look "round"?
thanks in advance
Banana.man
Hi, I've been following this thread for some time, please give me some feedbacks on my diamond. So sorry but I need help with posting of my images as well.:(
imgur dot com/vFtV6H3
imgur dot com/y8mrRK9
imgur dot com/njCYj38
imgur dot com/vAaAj5a
imgur dot com/m7KM4ub
imgur dot com/SipvbK3
0.48ct
VVS2
G colour
phoenixrule
phoenixrule
0.48ct
VVS2
G colour
Banana.man
thanks in advance
Hi, I just got my diamond + setting from JP with ard the same budget as you. I was told that it was impossible for a 0.5 carats super ideal cut with a relatively good colour + clarity with that budget.
Most probably u will be looking at the range of 0.45 - 0.49carat..
ZippyRa
hey bro can share the details of your diamond?! :X
I have yet to sit down with jp yet but still curious abt different between super ideal and brellia apart from their shape. haha
ivandemi
thanks in advance
$3k++ should be able to get a 0.5ct in lower color and clarity.. like G-VS2. My Brellia 0.4ct+ was $2k++. But if you include your setting, I think will hit over 4k already. Super Ideal and Brellia are same pricing.
Why you want the setting to make your brellia round? Isn't the purpose of buying a brellia is for that cushion shape? lol
ivandemi
Super ideal and brellia is the same but in different shape. Both have the 8 hearts and arrows. But for a cushion shape diamond range, the Brellia is the most shiny one. The usual cushion diamonds have no hearts and arrows so that sparkles aint that good. Even Tiffany's cushion diamond is like that. I compared my brellia with their cushion and can see a big difference. Even the Tiffany SA ask me what diamond is mine :s13:
Jp have videos of it. You can try to search. This is one of the videos that convinced me to get my Brellia :D
lcyMaGiX
Hi bro, how much did you purchase it for? :D
0.48ct
VVS2
G colour
keithwb
Hi everyone,
sharing my hoot from JP, served by a nice guy lionel.
0.64 VVS1 E Super Ideal.
3D images:
The actual ring:
hwmook
0.48ct
VVS2
G colour
Its good, look like the one i saw in JP. Eventually my GF pick a 0.611ct G VVS1. This one should cost around $4k?
