Proposal Ring - Part 2
versionx
Hi guys, how do you guys verify the aset scope pictures they sent to you was the same diamond you saw at shop?(not the gia certs)
UNiteedy
Here you go
Can somebody help me upload? It keeps saying insufficient post counts.
These are the pics they helped me take with my hp from the hearts scope. Waiting for them to send me the proper scope pictures..
Brellia
Octagon
Octavia
Solasfera
Super Ideal
dijian
Bro.. both diamonds are pretty bad le..
GIA 5186155439
0.51 J SI2
EX/VG/VG
HCA 2.4
GIA 2186195279
0.50 J SI2
VG/EX/VG
HCA 6.2
Proportions are terrible.. their diameter measurements is actually around the same as a 0.4ct+ with a better cut..
If you get a better cut 0.4ct+ diamond, it will look the same size but much better.. and you can upgrade on the color and clarity too. SI2 is quite extreme le.. Summore with feather inclusion, if your diamond crack, gone case liao.
worth to buy if its 1.5k ?
GIA 5186155439
0.51 J SI2
EX/VG/VG
HCA 2.4
Dicer181
Brellia
ht tp://i.imgur.com/QMwiVex.jpg
Octagon
ht tp://i.imgur.com/KTb121D.jpg
Octavia
ht tp://i.imgur.com/Fs7QXtm.jpg
Solasfera
ht tp://i.imgur.com/GcVvxAT.jpg
Super Ideal
ht tp://i.imgur.com/QbILbQh.jpg
Oo.. what is this? This is something new..
Lost_Found
after weeks of looking ard, finally shortlisted down to the diamond from JP
JP had shown me some diamond and i had also posted the price/spec previously
but decided to choose from one of the 2 below after some consideration
Super Ideal - $4.9K
0.56 D VS1 3EX Fluorescence: None
or
Solasfera
0.565 E VVS2 $5,400
any butties can give some suggustion? TIA
beckslim
Hi everyone, Ive been lurking on this thread for the longest time and it’s now my turn to make a decision :) walk around many many stores looking for my diamond ring.. so far short listed jannpaul because they have the nicest diamonds....Im extremely fickle and feel bad visited 4 times already…
The problem Im facing now is which diamond I should get from them. They got so many diff cuts.
Super Ideal Cut (round)
Solasfera (round)
Brellia (cushion)
Octagon (self explanatory)
Octavia (squarish) but only 1 carat and so far never seen any comments about it before...hmm this look very different from the other diamonds need push budget up if getting a 1 ct…
please help me narrow down the good one to choose
so far i like the shape of cushion brellia the most.
but seems like a lot people going for solasfera...is it because is round so more people like it?
It'll be easier if you settle on which shape you like first.. then from there you explore the different cuts in that shape and slowly narrow down. What I like might not be what you like too.
beckslim
Super Ideal - $4.9K
or
Solasfera
0.565 E VVS2 $5,400
If budget permits might as well go for the solasfera for a few hundred more. hehe
tk
Super Ideal - $4.9K
or
Solasfera
0.565 E VVS2 $5,400
between these 2 I'd pick the super ideal.. but it's really up to your personal preference.. some prefer the look of the super ideal cut, some prefer the look of the solasfera cut..
Lost_Found
Yup the 3 digit is certified by AGS
Bad news, I was informed by JP that its sold!!
Super Ideal - $4.9K
They offered me another .56 certified by AGS also
Super Ideal - $4.7K
0.56 D VS2 3EX Fluorescence: None
RiRi85
Hi all I'm curious abt my quotation frm JP.
Super Ideal Cut
0.72 F VS1
Cost $7.3k
Does this seem right or did I overpay for it :(
I din't get D color coz i felt honestly you can't see much difference.
Sparkle wise it looked very good to me alrdy.
One more qn, does how bright / sparkly it looks depend on the color or the cut of the diamond?
Draculav
Hi all,
Can I know roughly how much this diamond is worth?
GIA 5156770207
Thanks
Its a very shallow diamond.. depth is v short, table is v long.
HCA score is 2.3
For better value, you can try downgrading your VVS1 clarity and improve the cut.. it will have a better visual impact.
Grizz.P
Super Ideal Cut
0.72 F VS1
Cost $7.3k
0.7x super ideal cut shld around 7k++ already. Sparkly is depend on the cut. Not color.
