Proposal Ring - Part 2
slashiroth
Just a quick question. Just looking for a simple setting diamond ring. Does jannpaul have them too? Nothing too fanciful. Budget around 2~3k.
thesal
I don't think they're super ideal.. HCA score is not that good..
Thought the one he selected is pretty good, price seems to be slightly lower than usual for the specs it has.
However, it's strange that it's still out in the market despite being certified in Oct 14.
aceminer
Why not? Oct 14 till now is only half a yr
xinping
generally can i get a decent diamond ring for less than a thousand? gf dont like to wear rings and stuff when i probe abit. so i think something decent will do.
aceminer
Honestly I don't think so. What decent U are looking at? G SI2? More info is needed for us to advice
sugaricing83
Hmm.. There is this lab diamond, orro. They do customised designs like JP. Prices start from a couple hundred.
xinping
i just started looking at this thread last night, zero knowledge. still trying to pick up the basics :D
actually i saw orro's ad on facebook, but i think fabricated diamonds not very good ba?
aceminer
I would suggest emailing jannpaul or calling them and make an appt:)
They won't hardsell and give U an idea of what diamond to expect with Ur budget
xinping
Are there anything I should look out for when I visit chain jewelry shops?
i supposed that is the very basic model?
superideal is actually the best cut in jannpaul. 1K+ probably is after factoring smaller carat and not so good colour and clarity?
as for what to look up at the jewellery stores, i suppose you should start with jannpaul and attend their educational course (free of course) and then visit a few others stores. like that at least you know what to look up for and compare between the stores.
good luck.
tk
Depends on your definition of $1k+.. if it's low $1k+, dun think u can get a JP super ideal.. if it's high $1k+, maybe can get a super ideal at 0.3ct range with simple setting..
No harm to tell them your budget and see what they can offer you. If you go to chain stores, they would have ready made rings in the $1k+ range. Good to learn more about the 4Cs as well as you go ring shopping. Important thing is to get one with GIA or AGS cert so that you know the 4Cs have been verified by reliable labs.
Silvialite
Is it just a gift for her or for proposing?
My GF doesn't wear ring as well. But she prefers something in the range of 0.5 carat.
Good luck. :)
Sessygurl143
Got my scope image. Anything else to look out for?
v-dateo
Hi guys, for the setting, is 18KT white gold good enough? How much do they charge for 18KT white gold setting?
valancefairy
not sure if i shd use 18k white gold or platinum for my diamond ring? pls advise
wonder wat's the price for using 18k white gold & platinum at JP?
HYHY123
Go google about the differences ? Basically, platinum is more durable, abit whiter? , heavier.. Personally prefer plat
Price is 500+ vs 900+ for standard designs..
