lazypix
- Aug 13, 2009
2-3 weeks I guess
Ok. Thanks!
2-3 weeks I guess
Hi fellow bros & sis (if any), I bought a diamond from JP today:
0.56 carat / F / VS1 / Super Ideal - $4450 (no setting)
Reasonable?
Oh yeah. Haven't really thought about that.
But most prob going for something with side diamonds.
Only know she likes bling and squarish unique diamonds.![]()
If she likes square, then Octavia might be better. It looks more square to me.
Btw, is it an Asscher or emerald cut? The shape and pattern looks similar.
I saw both the Octagon and Octavia when I was choosing my diamond too~
Really love how both of them look, Octagon looks really crisp when you see it sparkling. Octavia looks awesome compared to their "cousin", Asscher. hahaha! Hard choice between this 2! Both looks super nice!
This is the Octavia and Octagon. Sorry for the shaky video.. Its hard to hold and video with one hand.. haha
You might want to consider your setting design too and which diamond will be better for your design. For me, I knew I wanted a twisty design with side diamonds and was deciding between the Brellia and Octagon. After much deliberation and sleepless nights, I find that Octagon will go better with a twisty design and that's how I also picked my diamond.
All in all I am very pleased with the outcome and selection process... to a layman like me my SA Vince was patient enough to show me all the diamonds and Jann helped me with many requests on the design
Nice design! How long did they take to customize your ring? Do I need to show them the design I want or they will come up with something for me?
I changed my design afew times so mine too longer. If you have a design you want you can just show them. If not, they will suggest some for you.
Jann Paul can borrow the ring size measurer. But well i think u gotta be their Cust to even borrowhi all, extreme noob here but thought i shld just ask for some advice. Starting to think about proposing etc.
I know it might sound abit cheapo but my budget is about preferably 1-2k for the ring. We are both quite agreeable on not splurging to much on certain things so can save more for other things that we derive more pleasure in
Wanna ask
Which shops shld i look at?
What should I be focusing on? The style, carat and etc?
Any ideas to check out her finger size? or do shops provide like "samples" then after proposal if not correct can go back adjust adjust?
appreciate your comments.![]()
Hi,
I just reserved a brellia diamond from JP. Would like to hear some advice and comments..
This is the specs of the diamond.
AGS 104076852001, 0.454 carat, G colour VVS1 for the price of $3.6k with setting.
Is this price ok for the diamond??
I suggest u read through the posts here to find a ballpark.Just reserved a 0.532 carat super ideal cut from JP for $4.1k, VS1, G color, HCA of 0.7
was served by Julie
is it ok for this price?
Should be abt there
was served by Julie
Both is not visible to naked eye. I suggest u get what u like. But the min for me would be vs 1The agsl light performance report image do not look that symmetrical though.. is it still advisable to get it or wait for new stocks to come in?
Also, is it better to place more emphasis on colour or clarity?
yup, I can vouch for that. I thought mine wasnt that ideal but I went down to look at the scope and it was good.The Image on the AGS report is a "calculated image". It's not the actual photo. You should use the physical scope to see the symmetry.
