rochelletlovet
- Jul 24, 2015
Look nice. I also got the Octagon. May I know what is the clarity, color & carat?
Yours looks pretty tooooo~
I got a 1.1 e vvs2.
Also, below is a picture I took at JP. The diamond in the pic is a 0.75 G VS2 super ideal. Does anyone know if the main diamond would look dull and less bright compared to the side diamonds for such a tapered diamond setting? It seems the side diamonds look a bit too white too.. appreciate any advice, thanks vm
Hi guys this is a 0.75 G VS 2 super ideal, do the images look ok?
I noticed in the aset scope that a few of the arrows (eg 5oclock and 7oclock) are not touching the inner circle. Also, the hearts and arrow view have some inclusions along with their reflections.
Appreciate any advice, thank you very much!
You can refer to rlstine question a few post back. Both his and your diamond same colour, clarity and 3ex. Difference is HCA score but still both below 2, or 1 and 1.4 to be exact. And his is by 0.2 carat bigger. But he got quoted a lower price. Therefore, solely based on the info both of you post, nope not good deal.
Caveat : maybe his scope is not good. we will never know unless he does request and get them. thus the lower price for a bigger carat. but the figures he provided falls within center of a TIC diamond. very unlikely but still possible.
Bumpbump. Nobody bought their diamond elsewhere other than jp?Hi guys. Anyone bought their diamond or ring online via blue Nile? Any review?
BTW, how would you guys rate the importance of the features of a diamond. From most important to least important - Size, cut, color, clarity?
And any idea to get my gf ring size without her knowing or suspecting?
Sent from LGE LG-H815 using GAGT
Hi Tanghsi , isit ok to share how much u paid for the diamond ( without setting ) .
Diamond sourced by rlstine is from jp? Seemed q good
My first ring was from Blue Nile. The diamond turned out disappointing even though it was a triple excellent. Later learnt that diamonds can be milky, brownish or off color due to its properties and you would not know unless you see the diamond itself becos it won't state on the certificate. BlueNile has a return policy.. but after factoring the shipping cost and tax paid for it, I will be down few hundred dollars.. so no point to return also. I bite the bullet and bought another one from JP. From my personal experience, get a good one and just settle for it. If you settle for a mediocre one, you will upgrade or buy a better one again later. End up will cost you more also.
From the most important, I will rank CUT then Carat, Color and Clarity. Bigger carat also no use.. if the cut is too deep, diamond will still end up looking smaller. If you buy the best color and lousy cut also no use.. the diamond will still look darker from the light leakages.
Nope, Octavia is another type of diamond Jannpaul offer. I doubt anyone here bought it before.. Looking for reviews.
Just upgraded my diamond to a 0.61 e vs1 with jannpaul just now. Cant wait to receive d new ring w new ring setting!!!!
But my new diamond is AGS certified. Anyone's ring here is AGS certified too?
Sent from Samsung SM-N920I using GAGT
The Brellia cut i got for my wife a while back was AGS certified also.. At least the AGS cert will show you where is the location of the inclusion.
[/URL]![]()
[/URL]![]()
Thanks for your advice! But isn't the colour rated D, E, F, G & etc? Mind sharing what is the spec of the diamond did you get from bluenile?My first ring was from Blue Nile. The diamond turned out disappointing even though it was a triple excellent. Later learnt that diamonds can be milky, brownish or off color due to its properties and you would not know unless you see the diamond itself becos it won't state on the certificate. BlueNile has a return policy.. but after factoring the shipping cost and tax paid for it, I will be down few hundred dollars.. so no point to return also. I bite the bullet and bought another one from JP. From my personal experience, get a good one and just settle for it. If you settle for a mediocre one, you will upgrade or buy a better one again later. End up will cost you more also.
GIA diamond grading report does plot the inclusions in their report. Most probably what you saw is a GIA diamond dossier. Most diamond sellers will have the grading report as the price difference between the two is not alot.
Anyways, very beautiful cushion diamond. Your wife is a lucky lady.
Reason it's graded by AGS is because only AGS has a grading for Light Performance and GIA does not provide any Cut grade for fancy cut diamonds. On top of that, GIA does not provide any proportions such as crown and pavilion angle etc. Personal preference, I would choose an AGS cert over a GIA one any day.
