JurryL
- Aug 7, 2013
Can hoot the ring sizer from Qoo10 which is like a cable tie.
Sent from Sent from *******'s asshole using GAGT
hey guys, need your comment on this piece. should i worried about the light return map?
Light return looks less than ideal at the 2pm, 3pm and 4pm positions. Do you have any actual ASET images?
here is the aset image
Hi all,
was quoted $2850 just for the heart shaped diamond with following specs
Shape and Cutting Style: Heart Brilliant
Carat weight: 0.55
Colour Grade: D
Clarity: VS2
Polish: Excellent
Symmetry: Very Good
Fluorescence: None
Characteristic: Feather
Is the price ok?
Thanks in advance
BIG THANK YOU TO CONTRIBUTORS HERE!
Learnt a lot this past few months
Based on the findings from bros here, I know that JP diamonds are the best around and of good value!
Hoot a 0.71 carrot F VS2 super cut from them
This was my fiance ring the mom bought for her last time 0.51 carrot Ideal cutting also same price as my 0.71 carrot super ideal cut..
For that same price, I managed to get a bigger and much more sparkly diamond. When I compare them, the difference of 0.2ct is quite big. Maybe it's also because the 0.7ct one is a better cut.
Sparkle wise, the 0.7ct wins handsdown. Its much much more shiny.
my video =P
I din expect the difference between super ideal and ideal to be so obvious. Then again, I dunno whether my MIL kenna ketuk.. she said she was only told it was the best cut (Ideal) and wasn't shown the scopes.. oh well.
Moral of the story - Spend more $$ doesn't mean the diamond is better. Learn and check if the diamond is a good cut yourself and check them with the scopes. If I didn't come across this forum and learn from you guys, I would probably just ended buying off buying blindly from those jewellery shops.
Where is this from? Can't comment much as i don't usually look at heart shaped diamonds as it doesn't sparkle as good as round (You sure you want this to be your proposal ring? It might seem sweet if shes young but it gets 'childish' when older)
Hi, its from CAREZZA / The Engagement Ring Shop. This is chosen by her so no choice loh. It comes with GIA cert too
just collected my ring... really satisfied with the way it turned outAs with what other bros here said, can't get a proper clear photo because it is just too blingy
Yup if it's JP's sizing it should be HK size (cos the ring crafting is actually done in HK).
But I've come across various size charts for which the same "HK size" corresponds to different US sizes, so if anyone is intending to give JP the ring size for crafting, better double check it and if possible, bring down a sample ring that is in the correct size for them to measure. Best if if your gf goes along and can take measurements on the spot![]()
Nice pics! Looks bigDid you do 8 claws?
Hello guy, my gf just broke off the engagement. So I'm looking to sell the engagement ring.
Larry's Lazare diamond
0.71 carat
F Color
VS2 Clarity
I got it for 12.4k together with a white gold setting on a classic 4 prong.
Let me know if anyone is interested. Prices can be negotiated. Just want to get over and done with! The reason I got the lazare collection is because of its cut diamond which is known to sparkle. That explains the pricing as well. It's GIA certified too. Can bring to Larry to verify too.
Sorry to hear about this bro. You might have better luck trying selling it at Carousell. Larry's Lazare diamond is an Ideal cut but not Super Ideal cut.
JP is selling their Super Ideal Cut 0.7 F VS2 for arnd 7k. So its already priced much lower and a better cut. Unless you're willing to drop the price alot to less than 6k, it'll be hard for you to sell it here.
