Hi All,
Kindly help to check the scope image below whether it is a good diamond. Please help me to upload as well
h t t p://imgur.com/a/LZ9Bq
Diamond is swee x 2
Hi All,
Can someone help me to upload the scopes as well?
I am comparing between these 2 super ideal diamonds from jannpaul. Is there a better one between them or are they equally good?
Thanks for your help!
Diamond A:
h tt p://imgur.com/ohtQLyk
h tt p://imgur.com/W7mgqGy
h tt p://imgur.com/ovYDyYQ
h tt p://imgur.com/F1SzOqz
Diamond B:
h t tp://imgur.com/0HwUUiy
h t tp://imgur.com/T1EmYPW
h t tp://imgur.com/oXDvftR
h t tp://imgur.com/lfc8vy3
looks like the one i saw 2 days ago! is it a .51?Diamond is swee!
cannot nego ar?
Both diamonds looks good. What are their specs?
Diamond A:
Diamond B:
The price depends also on the amount of gold needed, not just whether the setting is simple or not.
2 settings of same design, one thicker and the other one thinner, of course will have a bit of price difference mah
Is there any difference between a GIA certified diamond vs a AGS certified one?
I was quoted by JP:
1) 0.804c F VVS2 $10300
2) 0.805c G VS2 $10100
Which one would be a better pick?
I was quoted by JP:
I was quoted by JP:
Thanks all for the input, it's a solasfera cut so I Guess that it would be more pricey?
I'm leaning more towards the F as well since the difference is only $200...
