Proposal Ring - Part 3
fir3bon3
Agree on the colour! Hardly find it "yellow" even for G.
Yeah. I've seen my G color diamond to be whiter than my friend's E color before. Thats why you should focus on the Cut as the priority. You get a D color but the Cut not good also no use.
fir3bon3
A noob question.
Is the girdle thickness important? Is there any ideal thickness?
Get the in-between thickness.
Though you should still use the ASET scope to check too. The girdle thickness is also related to the light performance - painting/digging girdles.
Read this - https://www.pricescope.com/journal/visible_effects_painting_digging_superideal_diamonds
xiaoyuer89
was quoted 4k for diamond, 500 for setting at Jann Paul. Is the price ok?
0.51 vs1 E super ideal
Anybody tried negotiating with Jann Paul before?
dante99
Micheal Trio doesn't sell Super Ideal cuts. They don't use the ASET scope and I was told that it wasn't "accurate" and the GIA cert was enough already. Lol
If you want Super Ideal cuts, then it's JannPaul. If you want normal cuts, a lot of places will sell them. Look around and compare la.
Thanks. Also how accurate is HCA?
1000smiles
HCA is useful but not 100% reliable. You should only use it to check if the diamond HCA score is under 1.4 to reject the lousy ones. After that you need to use the scopes. Lousy diamonds can still have good scores.
Gt1989
Octagon diamond
Hi, Can anyone help me see if this diamond is good? Octagon diamond from jann paul
dropbox.com/s/fvq28ot2tkpwvxd/Actual%20OB%200.614%20F%20VVS1%20AGS%20104093029001.jpg?dl=0
dropbox.com/s/q4xkm1bzcoq0xrk/Aset%20OB%200.614%20F%20VVS1%20AGS%20104093029001.jpg?dl=0
dropbox.com/s/j8g1q1hdbya4x54/Hearts%20OB%200.614%20F%20VVS1%20AGS%20104093029001.jpg?dl=0
dropbox.com/s/t7hzz66qn7ytexd/Ideal%20OB%200.614%20F%20VVS1%20AGS%20104093029001.jpg?dl=0
lcl_88
Hi Gt1989,
How do you post the links? I am unable to post links due to insufficient posts.
1000smiles
Hi All,
How do I post my scopes from jannpaul? I am unable to post links.
Upload it only any image sharing sites like tinypic or imgur, then share the link and we can upload for you. Dropbox also can but can't upload the image here. Only can download
lcl_88
I tried to post the links but it keep showing cannot post links due to insufficient post counts.
alibaba90
Hi All,
Kindly help to check the scope image below whether it is a good diamond. Please help me to upload as well :s13:
h t t p://imgur.com/a/LZ9Bq
:s12::D
lcl_88
Can someone help me to upload the scopes as well?
I am comparing between these 2 super ideal diamonds from jannpaul. Is there a better one between them or are they equally good?
Thanks for your help!
Diamond A:
h tt p://imgur.com/ohtQLyk
h tt p://imgur.com/W7mgqGy
h tt p://imgur.com/ovYDyYQ
h tt p://imgur.com/F1SzOqz
Diamond B:
h t tp://imgur.com/0HwUUiy
h t tp://imgur.com/T1EmYPW
h t tp://imgur.com/oXDvftR
h t tp://imgur.com/lfc8vy3
Gt1989
Octagon Diamond
Hi, can someone help me see if this octagon diamond from jann paul is ok?
h t t p://imgur.com/pYxYgpj
h t t p://imgur.com/8XFvjFX
h t t p://imgur.com/5ctcIfj
h t t p://imgur.com/wotys4j
