Proposal Ring - Part 3
bullfrog
G]
SIC cut really machiam photocopy.
Sent from 富贵山庄 using GAGT
Congrats! Looks good. But coming here for help when ur partner also active in hwz a bit risky right? She might find out u shopping to propose liao. But good on ya! :)
proless
Hi Gurus, just came back from JannPaul and placed a deposit ($500) on a 0.524 F VS2 Solasfera ($4,550). I am still waiting for the scopes. Please share your thoughts and I hope it is a good buy. Thank you.
Below are the diamonds that I am interested in given a budget of $4600, only the diamond itself, exclude setting:
Solasfera
0.516 F VS2
$4,450 (Including 7% GST)
0.524 F VS2
$4,550 (Including 7% GST)
0.52 G VS2
0.533 E VS1
$5,150 (Including 7% GST)
Super Ideal Cut
0.51 F VS2
$3,900 (Including 7% GST)
0.57 F VVS2
$4,700 (Including 7% GST)
0.54 F VS1
$4,100 (Including 7% GST)
0.54 F VVS2
$4,350 (Including 7% GST)
ilovemydada
Went to JP last week and got quoted 5800 for the diamond itself. With settings 6.3k plus. I think the sales person marked up quite high for this specs, what do u guys think ?
Here are the specs
Round brilliant
5.42-5.44x3.36mm
0.61carat
D
VS1
Excellent cut
Polish:excellent
Symmetry:excellent
Fluorescence:none
Clarity char: cloud, needle,pinpoint
KinoChoco
Here are the specs
Round brilliant
5.42-5.44x3.36mm
0.61carat
D
VS1
Excellent cut
Polish:excellent
Symmetry:excellent
Fluorescence:none
Reasonable, it's D color that's why more expensive.
PiPiChew
We shopped for the ring together. I'm not a romantic or play surprise type of guy.
We chose the rock and the setting together. Price also she know liao.
lacazette
Hi guys, 0.77 E Solasfera VVS2 with the following scopes for 9xxx, any comments on the scopes? (not enough posts to upload images/links) :(:(
imgur dot com/sUrqLz3
imgur dot com/tfDmVjH
imgur dot com/TwZQtHf
imgur dot com/dRTL1Rx
Cheers
testerjp
Cheers
Help you post
KinoChoco
Cheers
Solasfera is patented cut, all the scopes will look the same. No worry on it.
testerjp
Solasfera has a lot of small blinks looking from close, more like a glitter.
From far, super ideal is more noticable.
From close, super ideal also give sharper blinks.
I considered Solasfera but went with Super Ideal in the end, it's more practical. :o
KinoChoco
Same opinion as my partner, she prefers super ideal, well, unless you're looking at 2-3 carat Solasfera where all the small blings becomes big blings :s13:
x3dnd3x
Hi all,
I'm currently in the midst of looking out for a proposal ring. I don't know to set at what budget but my colleagues all say $6k max. So i would set a budget of $6k max for the proposal ring. I don't know where to start either. I only know how to buy computer parts. :sad:
Can i just check, regarding the specs that i see you people have been talking about, i should be looking at cut and grade. Any recommended specs? Like at my budget, what grade and cut i should be looking at if its at JP? :s11:
KinoChoco
Hi all,
That depends on what's your GF ideal diamond size, if it's 1 Carat, you're going to be looking at 10k~ for an ideal cut. I'll suggest minimally an ideal cut, can go for Super ideal too if Budget not your concern
x3dnd3x
Budget would be $6k max. I need to know what are the things i need to look out for. I seriously have no idea where to start.
Engagement ring buy abit more expensive. Wedding bands buy cheaper. Got people do like that? :s11:
testerjp
Bro, email Jannpaul and ask for appointment.
They will explain to u. I was served by one of the senior guy, Ranjit.
Very friendly sinkie Eurasian uncle.
x3dnd3x
They only entertain appointments only? Cannot walk in?
Because i work offshore shift, my off days irregular, sometimes today, sometimes tomorrow.
testerjp
If you want to walk in, suggest go during the weekdays, before 5pm.
But it's better to make appointment so they have an idea of what u need.
I made appt on a Saturday morning and went in the evening.
Ranjit don't work on Sunday if you wanna look for him.
x3dnd3x
Okay. Like that i'll make an appointment with them. See how it goes.
