Proposal Ring - Part 3
sentsggirls
My girl have big knuckles.
So measure the knuckles instead for ring size
any pros and cons for ring setting
cathedral type and non cathedral type.
which design is better?
Mr.egg
Hey guys, I had place a deposit of 500 at House of Hung but had decided to drop the deal.*
I'm willing to let someone take over the deposit with a discount of 20%.*
You could change it to other diamond too.*
Contact me at: 8ll2 5O32
ACAC0429
Can use the deposit for wedding bands?
theblueark
Should try to imagine it on the finger too. I would say cathedral can be overwhelming if the rock is small whereas classic helps to give the illusion that the rock looks bigger.
On the other hand if your rock is huge, cathedral helps to make the look a bit more balanced and grand.
But also depends on how the cathedral is designed. Can be made quite elegant and dainty or complicated and majestic.
CutiePie84
Went to JP and reserved a 1.5ct octagon diamond! Emailed them and got a slot in the same day. They assigned me this guy named william. I dont see his name much here... at first was hoping to get served by one of the popular staffs you guys experienced. End up william blew me away (no pun intended). He's dedicated and honest.. covered everything I need to know about diamonds. Didn't expect our session to take over 3 hours..
I'm going to customize a complicated design with them. Its going to be a very very intricate design.. heh heh.. william is still checking if its feasible to do it or not... fingers crossedxx
Took a video of my diamond. He let me play with it using the tweezer. Also showed me the diamond outdoors.. I've been to other shops before JP and I must admit their diamond does stand out man. When you see it with your own eyes you'll know what i mean.
He showed me my diamond's number on the screen. The Octagon has more markings on the different sides. Apparently, all diamonds with cert will have these serial markings to verify the diamond.
PS. the white dots you see are just dirt.
This is the ASET scope I took. I forgot to take the other scopes.. they're going to send them to me anyway and i'll upload them later.
Going back there again this weekend to discuss my design.
maximusw0109
Nice diamond! Wat design are you going?
KingKenny
Their Super Ideal Cut 0.5ct is ard 3k. So the Octagon shld be ard 4k?
They got new Octagon diamond shipment few weeks ago. I saw their new shipment video until jelly :s13:
nonameisme
Hi.
I’m looking to get damiani proposal ring. Anyone purchase that before?
What’s the price range of that? Any expert knows?
Thanks!
Yorksan
jannpaul
Went JP yesterday for first appt and was quoted the following (both diamond alone):
1. 0.53 F VS1 - 4050
2. 0.51 F VS2 - 3800
please comment! Also, have anyone tried bargaining the price before?
Thanks!
sugaricing83
Wah, how much for the rock?
