Proposal Ring - Part 3
lance88
Signature casing sorry. Rather simple design but nice.
I'll go HoH see what they propose. Thanks.
If its those 2 choices, I would pick the 2nd due to price to specs preference. But I would always suggest that unless you have a really petite partner, 0.4 is not the way to go. Down Clarity, Color is good, but up the Ct.
Let us know how HoH went.
exoticeclair
Hi all, could I check on whether you’d recommend a four prong or six prong for the diamond setting (0.41c round)
throwawaygrad
Definitely 4 prongs for me, and I'll recommend a cathedral setting. Set my diamond in Tiffany and cathedral settings before and the cathedral really made a huge amount of difference.
Miltah
4 prong will be more squarish and expose more of the pavilion or sides
While 6prong will be more circle.. but as yours is 0.41c, u have to decide if thats too much prong to diamond coverage for your liking
xiaosen
Can anyone help to comment this set? Thanks
Sent from Xiaomi POCOPHONE F1 using GAGT
cyl1987
i managed to get the ring box with special designs at Kaepsel... Pretty good quality!! For those who are looking for an ideal ring box can get it here...
just google for Kaepsel and its there...
Just for sharing to those who thinks the ring box design is plain...
throwawaygrad
Does anyone know the price range of a JP/HOH diamond of about 1.15/1.25ct?
For example how much for triple Ex, Ideal, Super Ideal...
zackontherun
Hi, my budget is around 10k or less. Looking for 1ct, excellent cut, simple setting. Probably gonna check out jannpaul but havent. Is it possible to get 1ct with 10k from jannpaul?
evelynleebali
I doubt 10k can get a 1ct super ideal. Maybe more like 0.9ct?? unless you consider the ideal cuts or excellent cut from their HOH side, it might be possible.
Miltah
1.01c G, vs1, $14k (SIC), this price was from abt 3mths back.
And G is already their lowest color that they carry...
espressoull
Received the scopes for an Ideal Cut Diamond I'm looking at. Would like to check what do you guys think of it? Thank you!
drive.google[dot]com/open?id=1p1VLP8hTMwklIRfVmprO4NeXgiYft71J
KinoChoco
Sent from Xiaomi MI MAX 3 using GAGT
Might look weird in real considering the prongs are thick due to the diamonds embedded on the prongs, that’s my personal opinion. I’m a fan of micro prongs (I always request for the smallest possible yet safe prongs size to showcase more of the diamond)
