1000smiles
- Aug 14, 2012
0.83 E VS1 Gia 1215351154
The proportions are not very good for this one.. the crown should try go for minimum 33 degrees and the pavilion is too steep. Did you try seeing the diamond with the ideal, aset and hearts-arrows scopes? Those are more important to use.
You should try using the HCA http://www.pricescope.com/tools/hca to check it the proportions are ok. Make sure it is less than 1.4
Diamonds with low hca score can be bad too. So you need to use those scopes to double check.
