Proposal Ring - Part 3
KinoChoco
Hi, I have recently bought LeeHwa Destinee diamond ring. I was only given Destinee diamond qualification report but no AGS report. Do anyone bought recently and know if they do provide both reports? I am currently overseas, thinking to check here before I go back to LeeHwa store.
It should always include a AGS cert as per their website indicate.
Or perhaps you purchased a diamond which the size fall below the min-requirement for AGS cert?
Miltah
Yes if your stone was less than 0.2ct.
AGS will certify from 0.2ct.
Not providing one from 0.2-0.3ct is basically saving cost
WengWeng1
I have purchased 0.4 carat as discounted price. Maybe the cost saving is on AGS certification? I should ask them clearer...
KinoChoco
This is totally weird. Not to be offensive, are u sure it's destinee that u purchased? If it is, then the salesperson really messed up big time lol.
edit: i dont remember destinee gives any 'discounted' price other than maybe the usual member/bank 10%.
zackontherun
Hi I need help/some opinions with this
So I've been to a workshop near tiong bahru and jann paul. Basically the workshop one is a lot cheaper compared to jann paul but the quality difference between the two isn't that huge?
Tiong Bahru workshop:
0.8 carat E VS2 $6300-6500
https://photos.app.goo.gl/xWTfXQTJg5zQPjdF6
This is jann paul:
0.72 Carat F VS1 $7000
https://photos.app.goo.gl/e6Y6nt23G8eduG7x9
https://photos.app.goo.gl/q5kDi4BhRWfG8rtu7
I'm quite stuck between the two. On the other hand, theres also a 0.82 carat one from jann paul thats 8.3k which is quite insane but I'm also considering. Any opinions would be greatly appreciated. Is there really a huge difference between the two? or the lighting only
Miltah
This is jann paul:
U dun need answers here. I believe u got everything u need from pricescope.
Depends on how much u value super ideal. If u really want to compare the tiong bahru stone, u should use a HOH ideal on pricing
blurpandasg2014
This is jann paul:
Did u take pic of the cert for the Tiong bahru one. I think u went to poh kim. Heard its really affordable
WengWeng1
Can see the reflection of lights is good anyway. Just that I wonder why no AGS cert provided.
Also have 8 arrows...haha but cant attached picture..do not have sufficient post count...lol.
Miltah
Your in hse cert should at least have a AGS or GIA grading no.
If dun have then I really dun know what u bought
Miltah
SIC 0.83 F VS1 $9300 worth?
Take this guide with a pinch of salt but personally I’d spend abit more to push into the 0.9c range. Qs is if there’s stock ...
JP/ HOH
0.41c, F, VS2, $1950 (ideal)
0.31c, E, VS2, $1850
0.37c G, VS1, $1950
0.35c F VS1, $2450 (Solasfera)
0.37c G VVS1, $2400 (Solasfera)
0.41 D VVS2 $2950
0.41 E VVS1 $2850
0.43 E VS2 $2750
0.43 D VS1 $3050
0.43 E VVS2 $2900
0.58 G VS1 $3,250 (ideal)
0.56 G VVS2 $3,300 (ideal)
0.58 E VS2 $3,500 (ideal)
0.52 G VS1 $4200 ( including white gold ring)
0.54 G VS1 $5000 (ring plus side melee include)
0.63 F VS2, $5100
0.60 E, VS1, $5400
0.72 F, VS1, $7000
0.76 G VS1 $7200
0.77 G VVS2 $7700
0.6c G VVS1 $6k (Solasfera)
0.6c, G VS1, $6k+ (Solasfera)
0.65c E VS1, $7.1k (Solasfera)
0.83 F, VS1, $9300
0.96c G VS1, $10.2k
0.96c E VS2, $10.7k
0.98c F VS2, $10.8k
0.92 F VVS2 $12,400
0.95 F VVS2. $13,600
1.01c G, VS1, $14k
1.02 G VS1 - $14,300
1.09 G VS1 - $15,000
1.10 G VVS2 - $15,300
1.05 F VS1 - $15,800
1.01 E VS1 - $16,000
1.21c G VVS2, $18k
1.54c, G, VS2, $25k
BuaySaiHippo
Hi guys,
Is it wise to go for a diamond that is not triple excellent?
The symmetry is only very good but the other characteristics are very much to my liking, especially the price.
Any advice?
iamnotshawn
Hey Miltah, You can add these to the list too
0.72 F VVS2, $6100 (Ideal)
0.73 E VS1, $6200 (Ideal)
0.74 G VVS2 $5900 (Ideal)
Miltah
Hi guys,
Any advice?
I’m not sure what other characteristics u talking abt other than price.
I wouldn’t as I know a triple excellent is not even that great to start with
CheeRs87
So by your definition, any stone which exhibit very little variation could be considered a SIC
I read my sentence and realized I shld reword it. I meant SIC is like almost identical in all the scopes. The little variations I mean is the facet reflections or color variations. lol
CheeRs87
Hi guys,
Any advice?
I'll aim for Symmetry minimum Excellent. Like Miltah said, Excellent itself is not exactly good or safe.
Imagine a pie with 8 slices. The diamond has ''8 sides'' or sections. The angles on the certificate represent the average angle of each of those section.
When the crown angle is 34 degrees, for a good diamond will have all 8 sides at exact 34 degrees. For a bad one, it can have like 32,33,35,35,33, etc. which averages out to be 34. This scenario can exist in an 'Excellent' symmetry. So you can imagine how worse it can be for a ''Very Good'' symmetry.
In the triple Excellent, if you really want to sacrifice one of them, I would choose to sacrifice the polish. That will have the least effect out of the cut and symmetry.
Lucas28
those without bracket remarks mean SIC? wondering why there's no SIC for range 0.5to0.59, no worth to buy in term of price per carrat?
JP/ HOH
0.37c G, VS1, $1950
0.41 D VVS2 $2950
0.41 E VVS1 $2850
0.43 E VS2 $2750
0.43 D VS1 $3050
0.43 E VVS2 $2900
0.63 F VS2, $5100
0.60 E, VS1, $5400
0.72 F, VS1, $7000
0.76 G VS1 $7200
0.77 G VVS2 $7700
0.83 F, VS1, $9300
0.96c G VS1, $10.2k
0.96c E VS2, $10.7k
0.98c F VS2, $10.8k
0.92 F VVS2 $12,400
1.01c G, VS1, $14k
1.21c G VVS2, $18k
1.54c, G, VS2, $25k
Miltah
Yup no bracket means SIC.
Prices are based on pple who posted last 12mths thereabts. If no post, then of cos no data.
0.5c - 0.7ct is also the next price bracket, so since u are already paying the next range, makes sense to get more value by buying 0.6 upwards
BuaySaiHippo
This is the GIA no. (5323094121) of the stone I was referring to.
Mind help to take a look at it?
