Hi all,
I'm personally looking to propose to my girlf. Are there any recommended jewelers you experts would recommend? I've read the thread briefly and see JP being mentioned a lot, are they still the go-to jeweler?
Also, I have a budget of about 4-5k and am looking to get an emerald cut as that's what my girlf adores. But she might be leaning towards the round cut with each passing day
What's the most value-for-money based on that budget based on the usual suspects - 4 Cs?
Do pardon my ignorance!
Sharing scope images of 2 identical size stones.
One is a AGS Triple Ideal, G-SI1. The other is a GIA Triple Excellent, E-VS2.
Which is which?![]()
Hi all,
), then subsequently found out JP SIC is an equivalent but at much better price
) JP SIC does not have the exact caret I need, but only a HOH
I think u were initially after a JP SIC but in a very special caret weight.
Jp didn’t have any and time was running out so they offered u a HOH but u decided to call another stone in to compare ....
I’m not even sure if JP do emerald. As side stones yes but as a main stone? U gotta ask
Emerald cuts are cheaper but for the savings, u lose it back as u need to go higher color n clarity.
Color n clarity shows up more, as well as light leakage in that cut
What I learned over the past month sourcing for a stone. Most value and safe ... G-VS2. Next check for ideal cut dimension, and finally verify with actual scope images. Then go for the biggest stone your budget allows.
One example of a stone that falls under the above:
https://www.briangavindiamonds.com/...0.624-g-vs2-round-diamond-ags-c-104104773100#
Hey guys my Boyfriend surprised me with a JannPaul appointment today! My wax model of the ring is ready and they let me bring it home hehe. It’s so fun haha. But sadly it’ll be the last time I see my diamond before it gets mounted.. so happy and excited for it!
Here are some pics and video
https://imgur.com/a/nUomqcd
Is the bottom one the one you bought from HOH?
I've got a budget of 10-12k and would ideally try to find something around 1 carat on cushion emerald or princess cut. The ring itself I'd like to have my girlfriend customise herself
Hi all, thanks for all the valuable inputs and have gained knowledge quickly with all the info here. Went to two jeweler and one being JP, eventually deciding to go with it like most here. They have send me the scope images, as with consencus here all JP diamonds are qc’d but would like to still ask for assistance to vet as I see some spots in the aset and ideal scope at 6 o clock area and to ask is that a issue and is there any other I missed.
Yes the girdle is uneven at 6.
Not an issue. Just not as perfect
Thanks Miltah. But do you think it can still be considered an SIC? It seems that 7 and 5 30 o clock seems uneven too or am I mistaken? And for uneven girdle, does it causes less bling.
Thanks for your feedback, I've gone to JP and on the 9-10k range for their Cushion Brellia diamond the highest carat range I can get is 0.88 cts Ideal cut VVS2 G for 10.3kDo u know what u want? Do u know what she wants?
Even if your gf can custom the ring, a cushion, emerald n princess are 3 totally different shapes.
Assuming u mean cushion, that’s still an oval vs a square.
Certainly going to a shop n seeing the stone will help u decide ...
There is no exact definition for SIC, any brand can consider their stones to be SIC.
But based on JPs past stones, then this is less than their usual standards.
It won’t be less bling. Chances are if u picked an Ideal HOH cut, u might not even see the difference compared to SIC
