Proposal Ring - Part 3
Miltah
Thanks for your feedback, I've gone to JP and on the 9-10k range for their Cushion Brellia diamond the highest carat range I can get is 0.88 cts Ideal cut VVS2 G for 10.3k
Does that sound reasonable based on your experience?
The other options around 10k are at 0.83 cts with slighty better color or clarity grading (VVS 1 and E/F) however as I can't really notice any significant difference on those I'm more inclined for a slightly bigger stone.
For a brick n mortar shop, u get service, ring customisation etc etc so sure it sounds reasonable. Especially if u want to let the gf go thru the custom process.
But if u are a value person, there’s online options to consider.
https://www.briangavindiamonds.com/....015-g-si1-cushion-diamond-ags-c-104105165007
1.015 G SI1 $8700 (after gst)
https://www.briangavindiamonds.com/....075-h-vs1-cushion-diamond-ags-c-104104700006
1.075 H VS1 $9325 (after gst)
Collected my ring from JP! Very happy with how the final product turned out. Ring is very very well made and beautifully crafted. Diamond is superbly sparkly too and stands out. Very hard to take photos of it when the diamond is so reflective. Diamond is SIC 0.72 E VVS2.
Only qualm I have is I wish the ring box they give is smaller. Its quite hard to sneak it into the jean pocket.
I saw there is this 750 mark in the ring. Any idea what is it for? I dont remember requesting for it.
SushiBoy888
Nice ring! The 750 is the marking for 18k gold. That's normal for 18k gold jewelries.
cplusplus
Hi all, how is this Ideal Cut diamond from JP? Can tell imperfections using naked eyes vs a JP SIC?
https://imgur.com/a/SRaxeZA
0.97/E/VS1 ideal cut 12.9k
adrianh4rt
I believe Ideal cut is by HOH. Not Jp itself. But of cos they are affiliated.
Anyway i've gotten my Ideal cut by HOH. Naked eyes my partner n i compared it with the SIC Jp but we couldnt tell. So we went for the Ideal cut HOH. To each of its own i guess. You need to compare the actual diamond you're looking at to see if you can tell the different.
cplusplus
Yep, my bad. Was referring to HOH. Just wanted to know whether the scopes are close to a SIC before I take time to go down and take a look at the actual diamond.
TheDAB
Hey bros, besides JP, what other reputable shops would you recommend to go have a look see?
Besides JP, the next best option is the online route. Read the back posts and you can find a few suggestions. Weigh the pros and cons
Gambler.
just went JP few hours earlier to learn about diamonds, intending to buy a proposal ring soon.
then came here and read thru some of the pages.
I'm really astonished by the information. Props to some of you for the regular info sharing and reviews.
Miltah
Thanks @milthan & @CaptainFantastic for your advice few months back :D
The ring is finally here and while my gf loves it, my wallet is feeling the pain everyday...:s22::s22::s22:
That’s great. I’m sure she would love it.
It’s a stunning piece ;)
Miltah
May i know the damage?
Here’s a rough idea of expected damage
JP/ HOH
0.41 F, VS2, $1950 (ideal)
0.31 E, VS2, $1850
0.37 G, VS1, $1950
0.44 G VS1 $2100 (ideal)
0.35 F VS1, $2450 (Solasfera)
0.37 G VVS1, $2400 (Solasfera)
0.45 E VS1 $2300 (ideal)
0.41 D VVS2 $2950
0.41 E VVS1 $2850
0.42 G VVS2 $ 2650
0.43 E VS2 $2750
0.43 D VS1 $3050
0.43 E VVS2 $2900
0.58 G VS1 $3,250 (ideal)
0.56 G VVS2 $3,300 (ideal)
0.58 E VS2 $3,500 (ideal)
0.51 G VVS2 - $3,500
0.54 F VS1 - $3,850
0.53 E VS1 - $3,900
0.52 D VS2 - $3,850
0.52 D VVS2 - $4450
0.63 F VS2, $5100
0.60 E, VS1, $5400
0.60 D VS1 $5300
0.62 E VVS2 $5600
0.74 G VVS2 $5900 (Ideal)
0.77 F VS1 $5950 (ideal)
0.72 F VVS2, $6100 (Ideal)
0.73 E VS1, $6200 (Ideal)
0.75 E VS1 $6150 (ideal)
0.72 F, VS1, $7000
0.76 G VS1 $7200
0.77 G VVS2 $7700
0.60 G VVS1 $6k (Solasfera)
0.60 G VS1, $6k+ (Solasfera)
0.65 E VS1, $7.1k (Solasfera)
0.83 F, VS1, $9300
0.96 G VS1, $10.2k
0.96 E VS2, $10.7k
0.98 F VS2, $10.8k
0.92 F VVS2 $12,400
0.95 F VVS2. $13,600
1.01 G, VS1, $14k
1.02 G VS1 - $14,300
1.09 G VS1 - $15,000
1.10 G VVS2 - $15,300
1.05 F VS1 - $15,800
1.01 E VS1 - $16,000
1.21 G VVS2, $18k
1.54 G, VS2, $25k
jianhui1982
JP/ HOH
0.31 E, VS2, $1850
0.37 G, VS1, $1950
0.41 D VVS2 $2950
0.41 E VVS1 $2850
0.42 G VVS2 $ 2650
0.43 E VS2 $2750
0.43 D VS1 $3050
0.43 E VVS2 $2900
0.54 F VS1 - $3,850
0.53 E VS1 - $3,900
0.52 D VS2 - $3,850
0.52 D VVS2 - $4450
0.63 F VS2, $5100
0.60 E, VS1, $5400
0.60 D VS1 $5300
0.62 E VVS2 $5600
0.72 F, VS1, $7000
0.76 G VS1 $7200
0.77 G VVS2 $7700
0.83 F, VS1, $9300
0.96 G VS1, $10.2k
0.96 E VS2, $10.7k
0.98 F VS2, $10.8k
0.92 F VVS2 $12,400
1.01 G, VS1, $14k
1.21 G VVS2, $18k
1.54 G, VS2, $25k
Thank you Miltah:s12:
